4gfun
Supporting VIP
- 2,009
- 55
- Dec 10, 2007
Ask Me,
Virginia
For my Laser...
I have 2 good batteries and 2 alternators, one of which I know is working.
The Alternator does NOTHING to charge the car.
If you disconnect it while it is running, the car dies immediately. Yes, I know you aren't supposed to do that and I won't make a habit of it nor did I do that with the 2nd alternator.
I have swapped out the alternator relay and the 80 amp fusible link is good.
The B terminal of the alternator is at Battery Voltage as well.
Previous owner mentioned he left some ground off the tranny when installing it, but I don't see any missing grounds at all.
I even grounded the alternator to the battery with a set of jumper cables as a test.
I have swapped the ECU as well. VOM shows the tale of a fully charged battery slowly dropping from 12.5 VDC down to 9 volts until the car dies.
What could possibly be causing this situation?
I need more advanced tips to get me through this.
Thanks!
Thanks!
