Junzu
- 140
- 18
- Aug 21, 2021
California
Installed oem power steering rack, fluid in the reservoir foams and overflows when turning the wheel. Leaving the engine running and pouring in more fluid just gets sucked up fast. No leaks and all lines are tight.
Any ideas? Whenever I try to bleed the system the reservoir just foams and overflows, ps pump making noise consistent with running dry. First steering rack install, everything seems hooked up properly. Should I just try to keep bleeding system? Not sure why air is getting in the system. Connections in reservoir and pump also tight, never messed with em
