1. Join the Community!
air filter
Posted by olddsmer, Dec 26, 2010
Please Support Rix Racing
Please Support Feal Suspension
  1. olddsmer
    olddsmer Proven Member
    151
    Joined Mar 26, 2010
    middletown, Ohio
    Just wondering what air filters you guys are using. I have a Dejon intake pipe with a K&N filter on my 93 Talon 6 bolt setup. I was thinking of the Greddy Airnix but I dont know if it will work. My intake pipe goes to my mas which is attached the the base of the air can. The K&N just clamps to it. The K&N is so long it touches my Dejon upper intercooler pipe. Just looking for something different.
    Any suggestions are appreciated.
    Regards
    Greg
    "Olddsmer"
  2. rich3389
    rich3389 Proven Member
    829
    5
    Joined Dec 27, 2006
    Ocean springs, Mississippi
    I would upgrade your maf to get rid of the POS 1g maf.
    814  10
    1990 Eagle Talon TSi AWD
    manual · 1G DSM
    Loading...
  3. crazyboy81
    crazyboy81 Proven Member
    220
    Joined Feb 26, 2010
    sarasota, Florida
    5.2 in. o.d. top x 6.05 in. o.d. base x 10.7 height round hpR performance air filter
    BIG BOY D
    283  0
    1998 Mitsubishi Eclipse N/T
    · 2G DSM
    Loading...
  4. ryan90tsiawd
    ryan90tsiawd Proven Member
    66
    Joined Jan 26, 2006
    clarksville, Tennessee
    I'm running a Aem dry flow 4'' filter
    273  0
    manual · 1G DSM
    Loading...
  5. paul s
    paul s Proven Member
    541
    5
    Joined Nov 17, 2002
    kingston, ON, Canada
    Just get a smaller version of KN. Go on their website and get a shorter version of what you have, don't spend the money on anything else.
    476  0
    1995 Eagle Talon TSi AWD
    11.280 @ 134.340 · 2G DSM
    Loading...
  6. timm98gst
    timm98gst Proven Member
    375
    6
    Joined Nov 11, 2004
    Akron, Ohio
  7. We're on Boost
    We're on Boost Proven Member
    937
    83
    Joined Aug 25, 2007
    Seattle area, Washington
    If your K&N is the one that is made to be the stock replacement filter, then I think you are having the same problem I had when I was using this setup.
    As I remember, the filter element was correct and the problem was the Dejon intake pipe. It was supposed to put the filter in the "stock position" but it actually moved it about an inch further outboard. That was an "M" style intake pipe as I remember. Man I'm really pushing it with my memory now, this was about 4 years ago.
    So I asked Dejon to make a custom "P" style pipe that would be shorter than he normally makes them, and even another inch shorter so I could connect it to the turbo with a normal 2.75" to 2" silicone reducer hose instead of putting the metal pipe over the turbo intake which is what Dejon had in mind with their normal design.
    So I sent him this scan of a cardboard 2D mockup I made that for sure fit the way I wanted:
    [​IMG][/URL][/IMG]
    and it looked like this on the car - by the way this uicp is a home-made job, not a dejon:
    [​IMG][/URL][/IMG]
    So it fit fine, but I wasn't using the can over the filter, so the clamps at the seal on the base of the filter was a funky arrangement. I didn't have the can, If I did I prob would have cut the flange off the base and used it just to hold that gasket better.
    Plus, as people have said, the 1g maf is awful.
    When I went to the 3" GM MAF, I used the same 7.5" long Dejon "P" pipe and same silicone reducer at the turbo, with the K&N 3320 filter, all the stuff that is in my profile now. The 3320 filter is not very big, but I love it. This setup looks like this:
    [​IMG][/URL][/IMG]
    I do like the K&N air filters. They have a very good heavy duty construction, look great, work great. That screen that they bond over the outside of the element really helps it hold up.
    4K  19
    650 whp · 510 lb/ft · 1G DSM
    2K  0
    manual · 1G DSM
    Loading...
  8. ulitka
    ulitka Proven Member
    146
    6
    Joined Apr 9, 2009
    Raleigh, North Carolina
    871  0
    1998 Mitsubishi Eclipse GSX
    16.665 @ 93.120 · 2G DSM
    Loading...
  9. olddsmer
    151
    Joined Mar 26, 2010
    middletown, Ohio
    Thanks for the quick response from all of you. Now I have some
    ideas to work with.
    Regards
    Greg
  10. Gus@RRE
    Gus@RRE Proven Member
    69
    Joined Dec 20, 2010
    Long beach, California
    Greddy filter sucks, the plastic cage that holds the filter element is brittle and excess vibration under the hood will break it. Currently running AEM dryflow filter, works great.
  11. talontsiboy24
    talontsiboy24 Proven Member
    813
    3
    Joined Mar 28, 2009
    60457, Illinois
    What do u guys think about this air filter= Vibrant Performance ::.
    I wrote to vibrant performance asking why they say not for turbo use and they said= In response to your question, our open funnel can work with turbo vehicles but only up to a certain horsepower rating for maximum horsepower. Ideally, naturally aspirated engines generate a smaller amount of stress on the filter which is why we designed the open funnel for those particular applications. Conversely, our classic air filters are designed with a higher flow rating and stronger base which makes it more suitable for turbo applications.
    Sure, our open funnel can work on some turbo applications like your vehicle but generally, we suggest our classic filter as it is more durable and will produce more horsepower.
    and i wrote back=I just think the open funnel would make more power as its more opened then your classic air filter which would mean it would be drawing more air in correct? I think u guys are more worried that the chrome cap inside might get sucked into the turbo ive heard it happened before but my filter is not hooked up right to my turbo.
    I been using the vibrant performance open funnel air filter for a while and didnt notice any issues extreme psi and stm sell them so do other dsm vendors so i think they are fine to use wouldnt u agree? I didnt go with the k&n because it has a cover on the top so it would be blocking air while the vp open funnel is opened on top allowing more air to come in then the k&n.
    426  0
    1992 Eagle Talon TSi AWD
    · 1G DSM
    Loading...
    NHerron likes this.
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
