Please Support Morrison Fabrications
Aftermarket 2G Rear Carrier Bearing Mounts Are Now Available!
Boosted Fabrication
Supporting Vendor
10
69
May 29, 2018
Charleroi, Pennsylvania
The rear drive shaft carrier is a must have piece for swapping a 2G GS-T to GSX.
No more drilling spot welds to get a nasty OEM bracket from a junkyard car that's probably covered in 30 year grease.
Simply unbox, prep your surface, bolt your driveshaft up and in to ensure perfect placement and weld this new carrier hanger!
-Includes 1 weld on carrier, and 2 nuts for mounting the driveshaft.
Front hanger is the same between models and only needs bolts ran through the shifter area. We offer a nut and bolt kit for the front also.
Further modification is the exhaust hangers for the front exhaust mounting. Simply hang your AWD exhaust and put your rubber hangers on, line up the hangers, cut to length and weld in your hangers to the front carrier area. Please ensure the driveshaft is mounted before doing this to avoid driveshaft clearance issues!
