  • Send Us Your Photos for the 2024 Calendar - here's how!
Please Support Rix Racing
Advice
Scrymerr
1,368
4
Sep 22, 2002
Vacaville, California
I would like some advice from you guys as far as what turbo to get for my car.
I want to make 350-375hp as cheap as possible. Two choices I have are getting an B16G or a Big T28. I do not know anything about the T-28, other than it is a direct bolt on. The B16G would be nice, but I am not particularly looking forward to getting the pieces needed to install it in my 2g.
I have already checked out the tuning guide, and have basic mods. Just need some suggestions on turbo.
Thanks
AWDLATIN
483
Nov 3, 2002
San Diego, California
Just get a 20G. More flexability in horsepower potential. If you live in Cali, its going to be hard in making that amount of HP numbers with out using race gas on a 16G. No to mention, our gas is crappy. If you are not comfortable in using a J pipe, try to find a vendor that could perhaps rotate the housing and weld a 90 degree elbow on the compressor.
Scrymerr
1,368
4
Sep 22, 2002
I appreciate the reply. Like I said, its all about money here. I would love 20g but i think it would cost more than I can afford. As far as the T28, im kinda steering away from it because of cost. I do not want to pay the $270 or so for an install kit, but do not wanna go "ghetto style" either.
What about an 18G?
Thanks again,
AWDLATIN
483
Nov 3, 2002
Hmmm. Well, to be honest, if you go 18, why not just go 20? You can find some steals on the internet these days. If money is an issue, just buckle down and save for it. It will be worth the wait.
Scrymerr
1,368
4
Sep 22, 2002
You are right. :) Just found 20G for $799. Rated to 440hp. Then all I need is a LIP for $115, and i dunno if I need new oil lines or other stuff, but thats not too bad.
Where in CA you from?
thanks,
L2RTSiAWD
Honorary Moderator
11,533
22
Apr 8, 2002
Chandler, Arizona
If you are getting a 20G you will need some install peices or get the housing rotated like he suggessted above.
Mike 99GSX
650
Mar 31, 2003
Columbus, OhioUS
I hope you have a few more mods than what's listed in your profile if you're going with a 20g. You don't have an AFC, injectors, downpipe, or even a fuel pump:rolleyes: A FMIC would also be good but not necessary at first but most of all you'll need a way to tune it...logger:D
TwoLiterV8Eater
330
Sep 2, 2002
Gainesville, Florida
WHY pay 115 bucks for a lower intercooler pipe? I had an elbow welded onto my turbo so it pointed towards the stock intercooler location, then bought a 12" piece of 2" exhaust pipe for like 7 dollars, and VOILA..lower IC pipe problem solved. Of course I guess it matters how your intercooler is routed and such, mine just happened to go through the stock locations.
kazzam
139
3
Dec 4, 2002
st.pete, Florida
I have the fp ported big t28 and its fast, its awsome, its fun, however, top end is almost non-existent! I still beat all the v8s, but a big16 has alot more top end! But the big t28 is the most fun u can have! 18psi a little over 3k rpm and stront pull to about 5600, then it lets off... do it right, get the big 16g, or if it was me, i am getting the eta32 :)
DSMJim
3,328
40
Jul 24, 2002
If you can't afford a 20G then I think 350-375hp is out of yoru budget. You'll have to spend an a lot more money then the turbo will cost to get that type of power.
For cost effectiveness I would go with a 20G as it bolts on and you can port your manifold yourself and make up your own intercooler pipes to again save some money.
