Gstclipse69
- 666
- 15
- Jun 30, 2006
Columbia,
South Carolina
Ok, here is the scenario. The car died on the way to class a couple weeks ago. I pinpointed the problem to the car not getting fuel. I tested the fuel pump relay and it tested good. I checked the hot wire going into the top of the fuel pump harness on top of the assembly and it was getting power. I pulled the fuel pump out and it was working too. I then noticed the connector on the bottom of the fuel pump assembly that goes to the fuel pump itself was burnt up looking. So I got a replacement fuel pump assembly and now I can cut the fuel pump on with link. So that is working.
Now, I also have had an intermittent no start issue, that I kind of thought was the starter. So I get the fuel pump working and try to start the car and the starter isnt turning over. Ok, so I have a spare starter laying around and I swap it in. So now with the replacement starter in I go to hook the positive battery cable back up and I get a nasty spark, and the starter just starts spinning.
I checked all of the connections, the terminals on the back of the starter are not touching each other. The ground is hooked back up to the starter bolt. I dont see any obstructions to the wire anywhere. So now Im just stumped as the where to go from here.
I messed around with the starter connections some to make sure they were right, and I tried to connect the positive terminal again and it still makes a nasty spark/arc. What could be causing this? Or why would the starter just all of a sudden turn on by itself? Should I be looking at the ignition switch, starter relay, or looking for a short in a wire somewhere or what, or is there something up with the starter? If someone could point me in the right direction that would be great.
I checked all of the connections, the terminals on the back of the starter are not touching each other. The ground is hooked back up to the starter bolt. I dont see any obstructions to the wire anywhere. So now Im just stumped as the where to go from here. I messed around with the starter connections some to make sure they were right, and I tried to connect the positive terminal again and it still makes a nasty spark/arc. What could be causing this? Or why would the starter just all of a sudden turn on by itself? Should I be looking at the ignition switch, starter relay, or looking for a short in a wire somewhere or what, or is there something up with the starter? If someone could point me in the right direction that would be great.
Same thing, once the key goes to start everything dies, dash lights, radio everything.
