architechnik
- 690
- 10
- Jun 21, 2007
Glad,
Oregon
Hey, looking for some info on the relays for a 1g ABS system. My pump was doing that common whirr thing and not shutting off after the car had.
I pulled the battery terminal before I went to work, as I was already late and could see my power being out by the time I got back.
While at work I did some research on here about probable causes and figured I'd change my relays. I popped the cover off and found one relay and pulled it, reconnected the battery and it still was going. I thought if it were a stuck relay and I pulled it then it wouldn't kick on at all.
Is there another relay somewhere? Is the block next to the obvious relay (with an 'X' piece of plastic) also one and how do I get that one off? I tried to pull but nothing.
Hanes manual says to take it to the Mitsu dealer and no pics. NAPA only showed a couple of relays and none specific to the ABS.
Right now the fuse is pulled (off the block on the battery).
