A bit of help with the tuning...
etay89
866
5
Dec 27, 2009
Monroeville, Pennsylvania
Ok here's the setup. It's an auto GST spyder. 14b turbo. 3" catback exhaust, mbc, cold air intake, 255 wally, stock afpr (i know, i got it on order), stock injectors, 1g bov, boost gauge, aem wideband, apexi safc2, smic.
parts i plan on putting in the near future: big 16g, 550 injectors, afpr, upgrade the bov, switch manifold.
is there anything i can do to increase acceleration?
With the AFPR and 255 pump you could raise the base fuel pressure to stretch the injectors a bit. At 50psi you will have 7% more fuel, so not only can you raise the boost a bit, but you can pull more 7% more airflow across the board on the AFC, which will add a little timing advance.
not really with stock injectors. what boost are u running now
the car is my daily driver. i never go over 10 psi indefinitely. max out i believe its around 15psi, dont remember at the moment.
