James85
- 0
- Jul 24, 2019
sauquoit,
New_York
Rust free 98 Eclipse Spyder GST 5 speed for sale
95xxx miles, all original never modified. Purchased about 5 years ago from down south, never seen a winter and never drivin in rain since ive owned it. Runs drives and shifts great. Ive only put about a 1000 miles on it since i bought it. had big plans but have too many toys and no time so want to see it go to a good home. Power everything, cruise control, no issues everything works as it should. Stored indoors every winter. Top has been replaced, no leaks. Timing belt has been done. Since i bought it I put an Injen intake, full turbo back 3" stainless steel Megan Racing exhaust on it including a stainless tubular o2 housing, and an optima red top battery. Installed a rebuilt throttle body as the throttle plate shaft seals had a slight boost leak. No boost leaks, builds boost and hold its great. NO rust whatsoever, one of the cleanest ones you will see up here. Interior is in amazing shape for its age, leather is in great shape.
The bad: as you can see in the pictures the clearcoat is fading in spots, rest of the paint shines up beautifully. Could use some new tires as they have some weather checking but hold air and have never leaked in the 5 years ive had it.
Shes a little dirty in the pictures and could use a good cleaning. Lots of pollen under the hood from being out in the country.
Have the original exhaust and intake that can go with it. Asking $4000 obo. txt only 315 five seven zero 7367
Located in upstate NY just outside of Utica
