FlyinTalon
- 144
- 55
- May 24, 2009
jeffersonville,
Indiana
I just pick up a 100% stock 98 gsx eclipse and it's my first time owning a auto. The tranny is leaking fluid pretty good between were the transfer case bolts up to the transmission, thinking its the output shaft seal for the transfer case. My question is I got the front tires up in the air checking out the leak and I can spin the front wheels with the rear once on the ground if I get under the car I cant turn the drive shaft is that normal? I know I can't do this with my talon. thxs alot for any help.
