Justin DuBois
- 1,741
- 1,484
- Aug 15, 2019
Oakland,
California
That’s sick.Yeah - 90's racing electronics at its finest. When I melted the bearings out of my 7-bolt due to low oil - and the stock instrumentation gave no warning - I decided that instrumentation would never let me down again.
View attachment 684877 View attachment 684880 View attachment 684876 View attachment 684886 View attachment 684887
Yes awesome! I was aware of how to setup the coilover as far droop being 1/3rd total travel and all that, but have been curious about doing it with helper spring. Yes, the helper is quite soft and not one of the tender springs. Thanks for the link!! It will definitely help when the time comes.after watching you're insta video this ( link below ) IS the EXACT way to set them up properly! this will allow the most rebound and droop for you while allowing you to setup for hitting the bump stop before hitting the fender.
do no pre load as suggested as its not the best way for setting up coilovers with helper springs!
also are these helper 4lbs or tender springs? tender springs tend to be more lbs rating and can be a funny thing to dial in if its working with the main spring. tenders have to be more precisely matched and the whole cars data recorded to get this tender to work.
helper is simple close by hand spring that keeps the main spring in check. does nothing but that
follow the install details and you will get it setup up perfectly well and also note to remember NOW all heights are adjusted VIA the spring and NOT the lower shock perch
Its alot of faffing about but easily done. Allow a good 5mm ish for tire expansion gap of the fender also. Some people use cutouts of the wheel for weight and ease to check but it does not always tell you the final story if its tight or space around it all so its alloying jacking with a wheel on but its the best option going to be most accurate.Yes awesome! I was aware of how to setup the coilover as far droop being 1/3rd total travel and all that, but have been curious about doing it with helper spring. Yes, the helper is quite soft and not one of the tender springs. Thanks for the link!! It will definitely help when the time comes.
Does it crank? Clutch/cruise switches, maybe? When I tried to get mine running after swapping to a new car, I spent hours trying to figure out and that's all it was. Clutch switch mod hadn't been done on the new car and i completely forgot hahah. You did just rewire your whole car though. Looks great, excited to see it in action this year. Seeing everyone getting ready, this year should be an interesting one for the DSMs built for turning.Well, no fire up. Fuel pump and ECU come on, but there’s something wonky with the starter relay. I’ll have to look more into what’s going on hopefully today or tomorrow. But my buddy got the back half of the car painted, really liking how it’s coming out. Two or three coats of this paint and the interior will really look
Just something happening with the starter signal circuit. Keeps popping the fuse for the signal side of the relay. So I just have to look into that. Leaning towards the starter being bad. Gonna try a little test today, and then pull the dash and fuse panel and continue painting. Yeah! I’m excited for those of us that turn.Does it crank? Clutch/cruise switches, maybe? When I tried to get mine running after swapping to a new car, I spent hours trying to figure out and that's all it was. Clutch switch mod hadn't been done on the new car and i completely forgot hahah. You did just rewire your whole car though. Looks great, excited to see it in action this year. Seeing everyone getting ready, this year should be an interesting one for the DSMs built for turning.
