Galant665
- 95
- 53
- Oct 1, 2004
Las Vegas,
Nevada
1998 GSX auto. Got this car all stock. T25 was bad. Car was sitting in a garage. They didn’t want spend what a new T25 was from the dealer. Car obviously been garaged it’s whole life. Paint and clear is excellent. Interior is very clean. Guessing original owner was a woman. Second owner another woman but younger.
Work I have done on this car
Small 16. Feed from the pump.
Ported original manifold
Fmic. Original Apexi pipes new that I had
1g bov. 2.5 upper pipe T bolt clamps
Cone KN under stock airbox lid. Hidden and shielded from underhood heat
Engine is all stock
All new belts tensioner pulleys
New water pump
Installed new valve seals
Denso 550 injectors
Evo 9 fuel pump
New filters
Replaced all three u-joints on driveshaft only one was sort of dry. Other two were ok but replaced them all.
Tcase yoke is dry.
All axle boots are good. Replaced pass inner.
Rack and pinion is dry no leaks
New battery this month
New wipers front and rear
Tires are 75% tread
Stock wheels. Original paint and clear is nice. Rim edges can use refurbishing on a machine. Stock wheels make the car.
Built a 2.5 stainless 304 turbo back exhaust. Used a magnaflow muffler and tip. Looks stock and stealth. High flow cat.
Transmission was spotless inside. Guessing it’s been dealer serviced a few times. Installed a transgo shift kit
GM trans cooler
VDO vac-boost gauge
New power antenna
Currently has an Evo 9 stereo
Have an original double Din for car
Headliner is solid condition.
Power sunroof works.
This is a factory non ABS car.
New GR2 struts
New cross drilled slotted coated rotors
Car drives nice. It’s quiet. AC works well. Interior door panels are nice condition. Seats are fairly decent. Dash has no cracks. I have a Dash Mat to protect it. Console is like new.
Being a 98 it has the flashable Ecu. Currently running the Ceddy mods mass air map. Car is on 15 psi.
If these cars would have came from
the factory like this.
Have too many dsms. Was going to daily drive this car. And repaint it the original silver so it looks showroom.
Included with car is another OEM front bumper. Uncut for fmic. All mounting holes and tabs are perfect. And a set of new inner fender liners.
Headlights are in excellent condition as are the tails.
Car has 165k.
$9800. For more pics. Text 702-741-6987
Engine is all stock
New water pump
Denso 550 injectors
Evo 9 fuel pump
New filters
Tcase yoke is dry.
Tires are 75% tread
GM trans cooler
VDO vac-boost gauge
New power antenna
New GR2 struts
Car has 165k.
