Dragoneclipse
- 0
- Jan 16, 2010
Lewiston,
Idaho
Suspension
Tokico Illumina 5 way adjustible shocks with lowering springs
Front and rear Strut Tower Bars from Road Race Engineering (RRE)
Front and rear Sway Bars from RMDSM
Camber kit to adjust for the lowering.
Engine
6 bolt block swap About 17,000 miles on it
The motor has the 1st generation Rods and then it has 2nd Generation Pistons.
Bored .020 over
Balance Shafts eliminated
Ported head with all new valve seals and new valves
Big 16G turbo
Forced Performance Race Exhaust Manifold
K&N Intake
RRE Intake pipe
Full Apexi 3 inch downpipe and 3 inch cat back exhaust. (The downpipe does not have a cat, but I have the stock pipe with the cat on it for smog)
Polyurethane motor mounts
GReddy Type-S BOV
Drivetrain
TRE Stage 2 transmission (Good for about 500hp) Only 17,000 miles on it. it cost $2500
RRE Flywheel (11.5 lbs)
ACT 2600 clutch
Stainless Steel Braided clutch lines
Stainless Steel Braided brake lines
Cross Drilled Brake Rotors
Stock headlights just installed different than pic.
new passenger front axle
turbo timer. Uninstalled.
manual boost controller
Currently painted black with gold in it.
The bad
We just got hit in a parking lot on the left side. insurance is going to cover it, it may just take a week or two to get fixed. I'll send a pic of the damage.
Passenger side door cap is in the back seat needs clips. I'll personally give you a $20 bill to go buy clips from the dealer to reattach and call it a day.
more bad luck starter went out, I thought it was wiring harness so I bought a new one, but upon further inspection found it was just the starter. I have a new one on the way, I will be replacing this immediately after I get it in the mail.
I'm asking $5500 after it's fixed. I am negotiable. Or you can take for $4900 as is.
I can include extra harness for additional $100 I paid close to $200 shipped.
contact me at mr2ftw "at" gmail dot com
