2G 98 Eclipse GSX : Best Replacement Alternator Available in Current Market?
plcooke87
Dec 18, 2021
Austin, Texas
What is the best quality replacement alternator available in the current market?
Vehicle - 1998 Mitsubishi Eclipse GSX
TIA,
Patrick
After doing a lot of research I bought this from RockAuto.com 90A Mitsubishi Alternator & so far all's good. BBB Industries is the new electronics division of Remy. Remy used to be AC Delco's reman. sub before GM had to sell them off.
A good Galant 90Amp will be good as a direct replacement. Just get a good brand and should last you a long time
I work at a major auto parts seller.
The aftermarket ones are garbage. We are talking at best early 2000's remanufacturing and a part thats sit on a shelf for another 15 years. This is regardless of napa, oreilly, autozone etc.
I went through 3 different remanufactured ones, the first was dead on install, second barely made 12.5 volts, third had stripped mounting holes in jad to retap.
If you get a rebuilt one make sure it has a good warranty, that your oreillys or autozone will be understanding when you need a new one
