knochgoon24
DSM Wiseman
- 6,135
- 92
- Jan 29, 2008
Troy,
Michigan
I'm having quite a perplexing issue right now.
I just switched from the Evo 8 ecu over to a 98/99 ecu. I've reverted all the wiring back, put the 2g maf back on, and set it all back up for tuning on the 98/99 ecu.
I'm using CeddyMods 1.9.
So right now, the only thing that I think should be affecting the tune is that I have PTE 680cc injectors.
So I used:
Injector scaling - 680cc
Injector latency -
3.825
2.67
1.725
1.26
1.05
0.735
0.48
With that, the car was so lean that it maxed out all the fuel trims...
So I changed the injector scaling to 631cc. Still maxed out all the fuel trims.
Next, I changed the Injector latency to -
3.825
2.13
1.44
1.035
0.690
0.57
0.48
And with this, I'm still maxing out my fuel trims.
So I turned to adjusting my MAF scaling. Added 10% to every value.
This finally started making some progress.
All my LTFT have once again maxed out (I did reset them), but my STFT has dropped down near 0, finally...
So my question is, why have I had to add so much extra fuel? This doesn't seem right. The car runs great otherwise.
-I know the maf is still good because my friend just used it.
-It's not a boost leak or else I'd be pulling fuel, not adding.
-I'm now hitting 180 load at only 10.5 psi. Is this normal for the stock maf? It's been so long since I used one.
Something just doesn't seem right.
So I used:
Injector latency -
3.825
2.67
1.725
1.26
1.05
0.735
0.48
3.825
2.13
1.44
1.035
0.690
0.57
0.48
