Street Build 97 Talon TSI FP Green: Road to 500hp
Okay so I went with another route and ended up still getting a built block, but with 9.5:1 1400hd Wiseco pistons with Crower Billet rods.
I also bought a new turbo setup finally. Ported 20g tdo5, ported SBR manifold with open dump TiaL wastegate. I wanted a quick spooling setup just for street fun, so the tdo5 housing along with the 9.5:1 compression should spool real quick.
Here's some carnage from my last motor that blew
I should have this all put in within the next two weeks, I have to get the head rebuilt too because a few valves hit the pistons. Going to use evo8 springs/retainers while it's opened up. Then dyno tune, hoping to make at least 450whp
Engine is in! Deleted the cruise control while it was out. Need to relocate that battery to the trunk eventually and clean up those wires.. Any other suggestions to clean up the bay?
Picked up some Enkei EV5's too. Weighs 41lbs with the tire (Tire weighs 24lbs), going to weigh the stock wheels and see how much lighter that is.
Next up on the list;
-3" Intake pipe w/ K&N filter
-Tune
-Put on wingless hatch
-Install turbo timer
-Put on wheels
-Clean engine bay/Detail car
-Paint headlight housings black
Just an update on what I've done this last month
Here's some shots I took (With my cell phone)
Outlander brake upgrade with drilled and slotted rotors and Porterfield RS4 pads
Old rotors were garbage
Replaced the IAC because the car kept stalling (Had the crap brown one)
Reran the injector wire harness under the intake manifold and relocated the ignition power transistor under the IM. (Pain in the ass!)
Before
After
Next things on the list
-Install antisurge housing
-Spark plug cover
-Coolant overflow
-Manifold heat shield
If anyone's going to MOD next Saturday I'll be there
I've been meaning to update this build journal. (Don't mind the coolant overflow)
Couple pulls (FINALLY!)
My shifts weren't the greatest on this one
Decent 0-120 pull
