- Thread starter
- #476
JeffGS-T97
Supporting Member
- 1,113
- 878
- Mar 22, 2019
Muncie,
Indiana
Sorry for the short answer man i was at work. I tested them out. The car feels normal until moderate load is used. The other injectors were good for a bit then they began leaking, 3 of themLooks like about a gallon or two left in the tank. I’m sure I’ve ran it that low a few times in my 2g and I’ve never had issues from that. Have you ran those injectors before? Maybe they flow different. They’re low impedance injectors. Were the ones you were running the same shape? High impedance injectors are much narrower.
Saving money buying refurbished injectors really screwed me. I believe low impudence is oem so i went with that type of injector. This feels familiar though, the last time it felt like this was much worse but identical effect. I hit a big square cut from the road ripped the intercooler nearly in half. Mounted the IC higher this time, hard lesson to learn. Car could barely do 20mph on the way home. Really need to boost leak test again.
