Please Support Rix Racing
Please Support ExtremePSI
Sold 97 Eclipse GSX
PLDSM
338
400
Dec 8, 2013
Warren, Michigan
97 eclipse gsx awd 5 speed. 101,xxx on the vehicle. Previous owner sprayed the car 2 tone, dings and dents here and there. Black paint on hatch near the window molding is chipping off. Not much rust on the car.
-Factory rebuilt 6 bolt engine : acl main and rod bearings, fresh crank, balance shafts eliminated, arp head studs, all new gaskets and seals, new freeze plugs...
-Factory rebuilt head : new valves, stem seals and cam seals, big bore lifters.
Misc:
-New shocks with gc coilover setup
-All new front suspension, upper ball joints, lower control tool arms, tie rods, swaybar endlinks..
-Aftermarket headunit
-New windsheild
-Stock t25 with stock 2g intercooler setup
-New battery
-Engine bay dress up bolt kit
-3 inch Turboback exhaust
-All new timing components, timing belt, idler pulleys, tensioner pulley and waterpump
-New clutch, pp, and flywheel
-New clutch Master and slave cylinder
-Trans, tcase and rear diff all redline fluid
-Injen intake
Cons:
-No cat so CEL every once in a while
-Needs an alignment after all the suspension was replaced
-Small exhaust leak at downpipe flex section
-Small amount of rust in passenger side rear wheel well.
Any question, let me know.
Asking $4000. Raf 586-879-9796
