dieselgenset
- 41
- 7
- Apr 18, 2015
Longview,
Texas
I have a 1997 Eagle Talon TSI for sale. It is not a running vehicle. The engine and transmission are out of the car. This is a very clean car inside and out but needs an owner looking for a project. The transmission pops out of first gear every so often. The engine block was bad and I no longer have itThis is a FWD car with a 2.0L turbo 7 bolt engine.
Missing parts include: block, turbo, exhaust manifold, stock pistons, clutch assembly, injectors
Extras: I have a new 2.3L stroker kit and cometic head gasket that are included. I also have almost all the factory gaskets and seals to rebuild the engine including timing belt parts, water pump, & high volume fuel pump. The flywheel has been resurfaced, the stock crank has been polished.
Parts: Most of the used parts are cleaned/bead blasted and in plastic totes. Bolts are labeled in zip lock baggies. I have replaced a bunch of the suspension wear items, new rack and pinion, new shifter cables and shifter bushings, new hoses, etc
NEW PARTS LIST:
-cometic head gasket #c4234-051
-seal for water # M030764
-PCV VALVE #431227
-INJECTOR ORING KIT
-ORING KIT #MD622021
-GASKET #MR312761
-SEAL #MD343563
-SEAL #MD343563
-SEAL #MD365697
-4 LAYER EXHAUST MANIFOLD GASKET
-T25 TURBO REBUILD KIT
-CHEAP AFTER MARKET BLOW OFF VALVE(USED)
-NGK PLUG WIRE SET #RC-ME77
-WALBRO 255LPH FUEL PUMP #GSS342 AND INSTALL KIT(EXTREME TURBO SYSTEMS)
-WATER PUMP #MD972050
-TIMING BELT TENSIONER #MD308086
-IDLER PULLEY #MD156604
-TIMING PULLEY #MD182537
-TIMING BELT #MD326059
-CLUTCH FORK PIVOT #MD719602
-CLUTCH FORK #MD770506
-CLUTCH RELEASE BEARING #MD749998
-CLUTCH RELEASE #MD749823
-CLUTCH RELEASE CLIP #MD706185
-ACL RACE SERIES ROD BEARINGS #4B1185H STANDARD
-ACL RACE SERIES MAIN BEARINGS #5M1186H STANDARD
-RADIATOR HOSE #MB906429
-RADIATOR HOSE #MB906428
-SEAL #MD184946
-2 BALL JOINTS
-ENGINE MOUNT #MB844274
-THERMOSTAT #MD315301
-RADIATOR CAP #MD315301
-4 NGK SPARK PLUGS #BPR6ES
-INJECTOR INSULATOR #MD095402
-2 BOLTS #MF101229
-THROTTLE GASKET #MD184046
-OIL FILTER GASKET #MD185528
-TURBO ELBBOW GASKET #MD302262
-OIL TUBE GASKET #MR258477
-EXHAUST BYPASS GASKET #MD191897
-MAIN SEAL #MD359158
-2 SHIFTER BUSHINGS #MD719165
-EXHAUST GASKET #MD128901
-FLYWHEEL BOLT #MD302074
-2 CLIPS #MB547806
-THROTTLE BODY HOSE #MD193577
-OIL COOLER HOSE #MD39661
-THROTTLE HOSE #MD195053
-THROTTLE HOSE #MD112349
-GASKET #1064A040
$2500 OBO
NO TRADES
I MIGHT BE ABLE TO DELIVER ON A TRAILER FOR SMALL FEE
TEXT 210-213-0510
