  • Join the Community!
    DSMtuners is a massive archive of DSM information - but more importantly, it's a COMMUNITY! Join in and participate with other DSMers, and invite all of your DSM friends to make this place their home. Chat with others, create a build thread, post questions and answers. Get involved! Logging in will also remove many of the advertisements, along with this notice. ;) It will also allow you to view images in threads.
Please Support Morrison Fabrications
Please Support ExtremePSI
96 rear Corvette brakes on a 1sr g
pagosa dsm
393
16
May 7, 2005
pagosa springs, Colorado
My next modd is fabbing a set of 96 rear brakes off a 96 vette.They have the same overall height of 49,9 mm. The diameter is 304.8 mm and vented.They are 80 mm thick.The caliper is a PBR that has a built in emergency brake.
The rotor must be machined for the center hole to 89mm and redrilledl for are bolt pattern.
Next fabb some brackets for the caliper
Make some custom brake lines
I don't think the emergency cables will fit,longer cables.
I will keep you posted on the progress
Rick
1sttimedsmr
254
Dec 18, 2008
Hemet/San Ja, California
Due to the lack of rear brake up grades .That is a project I would love to see. :thumb:
pagosa dsm
393
16
May 7, 2005
I fitted the rotors today.I machined the center from 67mm to 89mm.I also had to drill 5 new holes for the wheel studs.Every thing fits perfect.I am waiting for the calipers,about 10 days for them.Keep you posted
Rick
ramsack
3,286
17
Dec 27, 2007
West Lawn, Pennsylvania
nice. i'm subscribing because i want to hear about this. there is really no cheap option for 1g people to upgrade brakes and keep the e-brake.
pagosa dsm
393
16
May 7, 2005
My cost for the rear brake upgrade
70.00 rotors
170.00 rebuilt calipers with pads
custom hoses not much
60.00 emergency cables 2
30.00 machine work,my lath is not large enough
0.00 I will make my own brackets
1sttimedsmr
254
Dec 18, 2008
So you are saying that he rotors you got did not have any holes or you got some other holes drill on them besides the ones they already had? PICS please.:pray:
pagosa dsm
393
16
May 7, 2005
Sorry I do not have a camera.I will take some photos as soon as posible. The rotor is drilled for a corvette.I had to drill new hole for the talon.Not very hard.
Rick
Photos of 96 Corvette rotors and caliper bracket in progress.
1sttimedsmr
254
Dec 18, 2008
Nice, I can wait to see some more pics. What is the size difference between the stock ones and those you have there?Keep it up though.:thumb:
pagosa dsm
393
16
May 7, 2005
The caliper is made of aluminum by PBR.It has an emergency brake with it.The Corvette rotor is 12" and 3/4" wide.It is also vented.The stock is about 10.5" and 1/2" wide and solid. I am waiting for the calipers,then I can finish the brackets .I will make some custom hoses.I think I will have to find some longer emergency cables
Rick
housegsx
2,455
32
May 28, 2004
Greensburg, Pennsylvania
Cool project for a 1g! Do you have your fronts done? The Baer kit would be a perfect match. FYI, cheapest GM OEM Corvette rotors you will find... ROTORS
pagosa dsm
393
16
May 7, 2005
I built my own front brakes.I got PBR calipers,2003 cobras.I fited crown vic rotors.The rotors are 12" x 1.18. I fabbed some brackets and brake hoses.Then a fabbed rings for the rotors. You can see some photos in my gallery.
Rick
pagosa dsm
393
16
May 7, 2005
This weekend I fabb up the bracket and spacers. I made the plates out of 1/2 steel and the bushings from 1" round stock I will have my friend cut them out with the plasma cutter on monday.I plan on installing them next weekend.I will have some custom brake lines made. The problem I have not research, the hand brakes cables.I will have photos soon. It was alot of work for me.At one point I thought they would not fit. If anybody knows where I could get custom hand brake cables please let me know.
Rick
AlaskanDsm
1,122
12
Oct 21, 2007
Fairbanks, Alaska
Its so funny becasue people look at me weird when they see my plate is from Alaska... almost like... they are trying to find out where my igloo is and why I don't look eskimo LOL.
But anyways, glad to see someone enjoying the Ak made beer!! :hellyeah:
pagosa dsm
393
16
May 7, 2005
I just about got the brakes done. I am lacking my friend cuting out the adapters ,adjusting the parking brake and bleeding the brakes.I will have photos soon.
AK Maniak
2,075
14
Jul 9, 2009
Butte, Montana
I'll be rollin with AK plates in AZ come august, and Alaskan Amber is some pretty damn good stuff.
pagosa dsm
393
16
May 7, 2005
Here it is. Check out my gallery for more photos.
<img src="http://www.dsmtuners.com/gallery/files/5/0/6/5/5/dscn1437.jpg" alt="Rear Corvette Brakes On 1g" />
donk
123
6
Dec 17, 2002
kalmar, Europe
Looks great! What made you go this way with the rear brakes ? I have the bigger rear rotors from TCE but when those wear out maybe this would be a better bet since the parts are pretty cheap and easy to get, even here in sweden.
/A
pagosa dsm
393
16
May 7, 2005
/A
I upgraded my front brakes and I wanted to upgrade the rear brakes. I must have looked for 2 years for some brakes to upgrade .I found the Corvette has the same height on the rotors as our rears.Also the caliper has a hand brake with it.I must have 5 to 6 days to fabb these brakes. The caliper weighs about 6 to 7 pounds.They are made from aluminum.
Rick
Boosted Fabrication ECM Tuning ExtremePSI Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com Raven Fabrication RixRacing RockAuto RTM Racing STM Tuned VR Speed Factory
