Sk8rRevoLT
- 0
- Apr 23, 2012
Van Nuys,
California
I have a 95 eclipse gsx with a 6 bolt swap 92 and im having a misfire occur.. stock ecu.. replaced parts here and ther got a 3 inch pipe for intercooler and 3 inch exhast straight pipe no cat. with no o2 sensor (rear) i get cel for that and i am running rich.. i get the maf cel as well since i dont haev the translator which i need to get and not sure ### itll do for a change my bov is aftermarket stock turbo right nnew ignition wires and spark plugs ngks.. and stock fuel injectors.. im getting a mad random cylinder misfire anyone could help me out with this.. i will post fotos of my engine and car... thanks to all
(REposted due to admin wanting specifics...) when i need help..
Also when i got the car my intake manifold coil ignition was lose big time and i had the guy end up fixing it up but he kinda did it in a odd way were it kinda stick out more rather then it being more underneath with the manifold idk if that would cause an issue? and how would i be able to check if that iginiotn isnt causing my misfire first of all? with carb clean be okay to spray?
bump.. anyone input please....
