CJ512
- 2
- Jun 20, 2009
Austin,
Texas
Completed build a couple months ago. All parts listed have less than 200 miles.
Block reworked by Park engine and machine in Seguin Tx. Torque plate honed @85.5mm crank shaft micro polished in very good shape. Wisco pistons, manly Hbeam rods. Balance shaft delete and 180 bearing. ACL race bearings. Arp head studs and new oem mains. New oem oil pump, water pump and timing set. Head was rebuilt using stock valves, Crower 272 cams, raised rate BC valve springs with titanium retainers. Aem adjustable cam gears. Car is currently running on a white shed speed chip for 880cc injectors. Aeromotive Adjustable fuel pressure regulator, Aeromotive fuel filter, Aeromotive 340 fuel pump. Will come with new ecmlink V3 full with new cable and speed density bundle. Comes with new RC 1200cc injectors aswell. Turbo is FP black with MAP recirculated O2 housing with new tial MVS wategate, 38mm. Slowboy racing manifold. Needs a block off place for old WG location. Some work done to trans, like new ITP end clutch kit and ITP shift kit. Car is lowered. Has KYB AGX suspension in good shape. All suspension components are new , sway bar end links,tie rods and ball joints.Full interior car with A/C and heat. Power steering. Lots lots more. Will post more pics soon. Feel free to ask any questions you may have. $6500
