PLDSM
- 338
- 399
- Dec 8, 2013
Warren,
Michigan
This is the Build Thread for 89 RAM 50 4g swap "Validation Plan". Reply below.
Sweet! Yea the t56 is pretty bulky so to set the correct driveline angle a trans tunnel will for sure be needed. A friend of mine has a t56 in his ls swapped c10 and he loves it so why not, being a 6 speed is great as well as parts are not hard to find so thats a plus.. looking forward to see how that ar5 works for you.Really excited to see how the t56 does. I'm currently doing a rwd swap myself with an AR5 trans but i scored a 2.4 6 bolt narrow block at the yard recently im gonna build to go in later and was thinking of going to a t56 for some added overdrive.
Copy that. Will let you know in a few months when its done and driveable.Yeah you just gotta either have some super low gearing or super down low grunt to pull 6th. That's either a .62 or .50 overdrive and alot of guys can't pull it or have boost creep issues. So curious how that 2.3 will handle it.
Thanks man.. yea so far its been alot of work, no light at the end of the tunnel yet but the vision is there.This build is lookin mean man! keep posting updates!
Thanks, lot more updates to come and more fab work thats for sure.Dodge truck and DSM: can’t argue with that combo! Nice call on a stoker motor. Fab work looks top-notch. Pickups and ladder frames do give a little more breathing room to modify, but this is simply impressive.
Yes sir, whatever gets the job done. Alot easier to do fab work when you actually have proper tooling but have to improvise and think on the fly most of the time.Creative use of welding gear!
