1. Join the Community!
Street Build 87 Mitsubishi Starion 4G64.3 Swap Time
Posted by C89ZX7R, Aug 13, 2014
Please Support Southbay Fuel Injectors
Please Support ExtremePSI
  1. C89ZX7R
    C89ZX7R Proven Member
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    STILL BUYING ENGINE PARTS.
    * Build List "Parts I Currently Have"
    6-Bolt 4G64 Wideblock
    6-Bolt 4G64 Crankshaft
    6-Bolt 4G63 Dohc Cylinder Head
    6-Bolt Pauter 156mm X-Beam Rods
    Jay Racing Billet Main Caps
    Kiggly Main Girdle Brace
    Kiggly Racing Beehive Valve Springs
    Ferrea Stainless Steel Intake & Exhaust Valves
    Ferrea Intake & Exhaust Valve Guides
    GSC Power Blue Intake & Exhaust Valve Stem Seals
    JDM Evo 8 Intake Manifold
    Holset HE351CW Turbocharger
    Arp Head Studs
    Arp Main Studs
    Jay Racing Front Water Outlet
    Jay Racing Blank Coil Plate
    Jay Racing GM Alternator Relocation Bracket
    Shaved Dual -AN'd Valve Cover
    Magnus Fuel Rail
    *Parts Being Used From Previous Motor
    Aem EMS-4
    Aem Smart Coils
    Aem FPR
    Aem Boost Solenoid
    KDM Mpi Intercooler Piping
    KDM 4" Intercooler
    KDM Radiator
    KDM 3" Exhaust
    Greddy Type-R Bov
    Motorad High Flow Thermostat
    Fenderwell Cold Air Intake
    Current Installed Mod List
    Drivetrain Modifications:
    Competition Stage 4 - 6 Puck Sprung Clutch
    Short Shifter
    Poly Transmission Mount
    GNT Torque Tube Bushings
    GNT Differential Mounts
    Suspension Modifications:
    S&M Front Tri-Point Strut Bar
    S&M Rear Strut Bar
    Cusco Front Adjustable Camber Plates
    Eibach Pro Lowering Springs
    Front Suspension Tech Larger Sway Bar
    Rear Suspension Tech Larger Sway Bar
    Brake/Wheel Modifications:
    Abs Bypass Line
    Refinished & Polished Rims
    Datsun Z Brake Reservoir's
    Slotted & Drilled Rotors
    Interior Modifications:
    Tan and Black Leather Interior
    Autometer Carbon Fiber Boost Gauge
    Innovate Digital Wideband
    35% Madico Tint
    Push Button 2 Step Shifter Knob
    Console Hi/Lo Boost Switch
    Aem Usb Ecu Port
    Electrical Modifications:
    GM 110 Amp Alternator
    Red Top Optima Battery
    Welders Wire Battery Relocation
    Custom Relayed Cooling Fan Harness
    Putco H4 Relayed Headlight Harness
    Silver Star Zxe H3 55 Watt Fog Bulbs
    L.E.D. Modifications:
    X2 Truck-Lite 5x7 Led Headlights - 2600 Lumens
    X1 White Ashtray Led - 10 Lumens
    X2 Amber Front Side Marker Led - 100 Lumens
    X6 Red Tail Light Can Bus Led - 420 Lumens
    X2 Amber Front Signal Can Bus Led - 100 Lumens
    X2 White License Plate Led - 150 lumens
    X2 White Reverse Led - 400 Lumens
    X2 White Front Running Markers - 260 Lumens
    X1 Third Brake Led - 62 Lumens
    X3 Door & Dome Led - 80 Lumens
    X1 CF12ANL-01 Led Flasher Relay
    Replaced Oem Parts:
    New Wheel Bearings
    New Control Arm Bushings
    New Strut Rod Bushings
    New Ball Joints
    New Tie Rods
    New Tie Rod Adjuster
    New A/C O-Rings
    Other Modifications:
    83 Metal Scooped Hood
    Anti-Roll Over Valve
    Rotella T6
    I have two wideblocks. One is a G64B and other is the 4G64. Using the G64B for the mock up build while I order and build the 4G64. Mock up pics below.
    P.S. CAR IS ALREADY WIRED FOR SPEED DENSITY USING A 4G63 SENSOR, WAS A DAILY DRIVER FOR THE PAST 12K MILES...
    IMG_82450686812187.jpe
    miliman13 and mitsubishikid like this.
  2. darknezz7
    darknezz7 Proven Member
    456
    78
    Joined Mar 30, 2014
    Eugene, Oregon
    nice intercooler routing in that thing
    very, detailed? mod list
    sounds like a fun project, these engines would be great rwd.
    that things gonna cook. (more)
    Showcar Build 11K  13  23
    1997 Mitsubishi Eclipse Spyder GST
    fwd · manual · 2G DSM
    Loading...
  3. mitsubishikid
    mitsubishikid Proven Member
    810
    171
    Joined Jun 8, 2009
    Turlock, California
    I love the rare early mitsu cars, you have a truly awesome star/quest there, so sad to hear the motor went on you, well at least you got as much fun and joy out of that motor before it gave up the ghost.
    Please do keep us all updated on the build man, I'm subscribing to this, I always love to see these awesome old nostalgic cars. kinda shame mitsu does not have an old school style rwd sports car like these to represent todays market.
    962  0
    1990 Eagle Talon TSi AWD
    manual · 1G DSM
    Loading...
  4. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    2.6L trash is out. Found a G64B block in a really tight spaced junkyard.
    [​IMG]
  5. Galant665
    Galant665 Proven Member
    38
    5
    Joined Oct 1, 2004
    Las Vegas, Nevada
    I did a 4G63 swap on an 89 widebody I got for $300. Rust free western car. Used a powerglide. AEM. Made a harness for it.
    476  0
    1994 Eagle Talon TSi AWD
    · 1G DSM
    Loading...
  6. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    Yea, Since Im staying 5 speed I need the wideblock "G63B or G64B", 4g63 is a narrow block doesnt bolt up to my trans.[DOUBLEPOST=1413735118][/DOUBLEPOST]
    What turbo manifold is that?
  7. mitsubishikid
    810
    171
    Joined Jun 8, 2009
    Turlock, California
    Are you gonna use a dohc evo 8-9 style cylinder head, or a do you plan on using the dohc dsm head.
    thanks for the update and keep up the good work.
    962  0
    manual · 1G DSM
    Loading...
  8. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    TY, will be using a 1g dohc head and intake manifold modified for rwd.[DOUBLEPOST=1413763924][/DOUBLEPOST]Here is how the old setup ran after cracking all four pistons. Two cylinders had low compression, one ring land was completely broken from the piston.. Still idled great LOL....
  9. Galant665
    38
    5
    Joined Oct 1, 2004
    Las Vegas, Nevada
    I built the header and intake manifold on mine.
    476  0
    · 1G DSM
    Loading...
  10. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    Pulled the head off the 2.4L block, OMG that is the worst Felpro gasket I have ever seen. Mechanic must have been a noob to not see that when putting it on.
    Cylinders are round but the gasket wasnt. You can see how the out of round the gasket was in this picture.
  11. tomica93
    tomica93 Probationary Member
    13
    53
    Joined Aug 22, 2013
    Zagreb, Europe
    2.4 gaskets arent round, just for the info
  12. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    Picking up Nib Ferrea Exhaust Guides and Arp Head Studs Today for 110 Bux.
    [DOUBLEPOST=1417965802][/DOUBLEPOST]Also picked up
    Found a used 1g head for 60 bux.
    extremepsi likes this.
  13. mitsubishikid
    810
    171
    Joined Jun 8, 2009
    Turlock, California
    Dude wish I knew how to weld, that intakes going to look nice, oh well, guess I got to learn baby steps first...
    what about bob.jpg LOL:D
    Are those springs, retainers, locks, also Ferrea brand?
    962  0
    manual · 1G DSM
    Loading...
  14. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    Friend does the welding. He will also be making me a top mount T3 manifold.
    Picture of his welds
    1912436_784696071587911_1016557486392134053_n.jpg [DOUBLEPOST=1418204837][/DOUBLEPOST]
    Kiggly Racing Beehives
    https://www.extremepsi.com/store/product.php?productid=23205&cat=1732&page=1
  15. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    Found another 4G64 6 bolt wideblock with a good crank in the junkyard today. Will be dropping them off to be cleaned and magnafluxed this week...
  16. mitsubishikid
    810
    171
    Joined Jun 8, 2009
    Turlock, California
    After some cleaning and inspecting, it should be real solid man:thumb:.
    962  0
    manual · 1G DSM
    Loading...
  17. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    Updated the 1st post. Also picked up the turbo for the swap, cant wait. "HE351".... Also just picked up the crankshaft from the machine shop, which said its in great shape. Thats a relief cause factory 6-bolt 64 cranks are really hard to find.
  18. Devilsfutbol17
    Devilsfutbol17 Proven Member
    355
    16
    Joined Jul 27, 2007
    Bellingham, Washington
    What are you planning to use for a Cam angle sensor and crank trigger? I am swapping my conquest in a few months because I bought it with a siezed motor and I also found a 6 bolt wideblock 4g64 and I'm looking into the options for cam and crank triggers.
    It looks like there are some hyundia 4g63's that have a head with 1g ports and have the spot to bolt on the cam sensor. That head combined with a kiggly crank trigger should do the trick. I plan to use ECMlink for my engine managment, I don't know how that differs for you since your using AEM EMS.
    Also I take it you're modding the head to move the coolant port to the front of the engine?
    568  3
    1991 Mitsubishi Galant VR-4
    manual · Galant VR-4
    Loading...
  19. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    using a 1g head so its the 1g cas
    Mine is already setup to run and has been with the G54B with mpi using a modded 1g cas, there is no wiring involved on this swap.
  20. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    Mail call. HE351 to 3" Reducer just came in the mail.
  21. Devilsfutbol17
    355
    16
    Joined Jul 27, 2007
    Any updates?
    568  3
    Loading...
  22. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    Pauter 6-bolt 156mm rods on the way, Jdm Evo 8 Intake Manifold is at the machine shop getting reflanged for the larger 6-bolt 1g head.
    mitsubishikid and CrackedDSM like this.
  23. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    Mail Call, 450 bux later. Seller stated used for 300 miles then parted out the car. There going to the machine shop for a spec sheet, if they dont come out to what the seller stated then we will go from there. Took a cap off and it fits the 6-bolt crank like its suppose to. Caps are labeled Evo 1 - 6.141. Still going to drop them off at the M-shop.
    mitsubishikid likes this.
  24. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
    Had the Pauter Rods checked out by Ballo's Machine Shop, yea same shop the Jafromobile uses.
    Pin Diameter .828
    Big End 1.889
    Length 6.141
    Rod 1 Weight - 645.7
    Rod 2 Weight - 644.6
    Rod 3 Weight - 645.3
    Rod 4 Weight - 645.7
  25. C89ZX7R
    76
    22
    Joined Feb 24, 2011
    Richmond, Virginia
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
