Please Support STM Tuned
87 Galant RalliArt 2.0TURBO 4G63BT
love the little details man keep up the good work, I worked on the sohc G63B/4G63BT motor loved how reliable it was, for instance if the t belt breaks no problem, just get another one, line up your marks, install it and start driving it again, sigh non interference is bliss.
head on its place, torqed
thermostan housing, camshafts, lifters, rocker arms etc ,all in its place
its really nice to put all of those things together while they are so clean
thermostat housing
thread locker on the oil plug for oil gallery on the head
again another box is waiting to be galvanized, and iam wainting for another box of parts from America, hope that is the last one :D
pics before and after galvanized
coil and power ignition mounts
then i got a third valve cover, painted in original silver with red letters combination
intake OEM gaskets and galvanized bolts
mediablasted intake manifold
before-after
and how an engine looks so far
Finally i got the turbo
it is MHI TD-05H Evo2 Big 16G turbp
evo2(left) and eclipse(right)
also i got an exhaust manifold and o2 housing from evo2
Aisin water pump came in
injectors from Evo 9 560cc
i was in Budapest for a New Year and i got few (read a lot) spare parts for Galant
4 of us were in Budapest so i need to organized it very well
also i got rare genuine mitsubishi wheels for Galant / Sapporo 81-84, as far as i know there are 4 sets in my country, and i have 2 sets :)
also for Christmas i got genuine front brake pads for EVO3 calipers
oil pan is installed
and for me this picture come true :)
lets make 2015. even better :)
finnaly i got the last package with parts
turbo is restored, had a few broken bolts in it, but now it is like new
Difference between Eclipse 1g and EVO2 exhaust manifold
Turbo is prepared
another round from galvanized
New and old water pump
New parts
also i got a new OEM fuel filter
New injector seals
Painted in black
Spark plug cables
Alternator
almost done, still have a few bits to put on
Engine DONE!
here a few pics of a details
After a really hard work, and 9times getting the engine out and in, i finally got the right spot, and balance
all work i was doing completely alone
modified engine mounts
fitted OEM Mitsubishi EVO 9 RS triple gauges
Next job was wireing
it was all running okay, but all the wires are old and have some oxide on it, so i have decided to build a new wire installation
all is from fire proof wires
Installation done successfully , look like OEM
and connectors for ECU
Do you have the sensors that go along with the RS gauges? I was planning on doing the same in my galant vr4 but from what I have learned you need the mitsu oem sensors for the gauges. One being the oil plug temp sensor from the RS/MR models, which are extremely hard to find working. If you have an alternative plan, please tell me.
What a fantastic build! Every little detail on that engine is superb! Keep up the tremendous effort!
yes i had all sensors, in fact you only need for the oil temp.
you can buy one from subaru, and welded it to the oil pan(or weld the nut as the subaru has different nut)
After fitting the engine, next problem was that engine moved forward, so there wasnt many space for the pipe from air filter to the turbo.
So i bought a SPAL slim ventilator, as stock one is really deep
here is the problem
Comparasion
and fitted, looks like OEM
much more space now
after completing the engine bay(all hoses connected etc), iam really satisfied how it looks
Oh my this Galant looks amazing! Great work Tomica.
From one Galant owner to another, great work.
Where did you source your intercooler piping from?
Beautiful work. All the little details like new hardware, tidy wiring, and clean components REALLY look amazing. Once again, awesome work. Looking forward to future updates.
So there are a lot of news lately, but slowly we will start with the new "phase"
car was hit by an old granny ONLY 24hours from the last picture :(
and after a lot of time and patience, all was putted in the previous spot, and bumper was repaired with special material (small tube cost 100e)
That sucks! Love this car. One of the cleanest 4G63's I've ever seen. Good luck with the rebuild.
Not sure if you mentioned it, but what method did you use to polish the brake booster, BOV, and wastegate if you don't mind me asking? Looks really good. Also wondering if they oxidized or began to corrode afterwards. Just curious.
at galvanize shop, dont know how you called that, but we are calling it "cold galvanized"
and yes wen you polish steel stuffs , they corrode soon, so you need to maintenance them
After getting the car in the shape before accident, i have finally decided for a full respray
that means, fixing all the extra holes, and getting the "clean look" for the bolts for side skirts and rear bumper
also removing any rust surfaces from the doors and the body. A lot of hard work for removing everything and preparing it for painting
Finally removed all the parts from the car
Here are the pics of the full respray, car was mostly flat AFTER 28 years, little here and there some dent etc.
colour is original ,Sarajevo Weis W18, but in clear coat it was added a bit of a crystal gold pearl, without sun or light you cant see it, it turned out very very good, and I was very satisfied with that.
preparing the car for painting
Preimer:
Ready for paint
Colour:
Painted :D
And some better pics after it got home :)
Some closer view
Slowly coming back together
a lot of time and effort goes for polishing
But first, PAINT protection , sealant and wax from soft99 fusso
Also cavity wax for doors and under the car
More cinced parts (some of)
polished edge on the tail light
Got a brand new HELLA rear plate lights with chrome look
little before after
And a rear end DONE!
