mike Cain
- 1
- Apr 22, 2019
Belton,
Missouri
Hi All. New guy here. A couple years ago, I picked up a 1st gen Mighty Max pickup. it had the anemic G63B motor in it, 5 speed, nice little truck. was disappointed with the performance of it, upgraded the carb to a weber, little better, but still a slug. did not take long to learn you can put a 1st gen eclipse motor in it. so the quest began....
Found me a 6 bolt 4g63t. ported heads, 272 cams, cometic head gasket, arp studded everthing .20 over wisco pistons, more that i can't think of at the moment, but just think "baddass" you get the idea. did all the mods required to get it to fit the new RWD orientation. swapped to a gt35 turbo, 38mm external wastgate, full 3 inch exhaust that exits in the stock location.. rywire harness and dsml
ink v3. am just now at the point where i turn the key, it starts, idles, and revved up a bit. shut it off and fixed the couple of little thingys that always show up. now,, this is my first ever venture into anything EFI so this is where my tuning learning curve begins . will scour the forums to get it all dialed in and hope to get it out on the street to see if I can break something. wish me luck and thank you for adding me. Mike
