timm98gst
- 529
- 8
- Nov 11, 2004
Akron,
Ohio
in case you don't get the magazine
http://importtuner.com/features/0502_it_covercar/
Note: This feature currently requires accessing the site using the built-in Safari browser.
wishihadatalon said:the magazine says that it has 600 flywheel hp.
a_scobel said:What's up with the ugly girl??
& why go with 19 inch rims, especially since they look like they're heavy..??
99redgst said:I can't decide which is more ugly, the girl or the evo. Whats up with that wing? :thumbdown
Quasimondo said:You must be logged in to view this image or video.
Georg51 said:First off, that thing is not 700hp. Yes the GT35R can promise that, but nowhere in the article does it say he dynoed at 700hp.
I know for a fact he can't be at 700hp on stock ignition. A local guy that I know personally has a 600hp EVO with a bigger turbo (GT45R I think), bigger injectors, and a coil-on plug ignition setup custom made by Tym Switzer. The car is built to the brim by AMS in Chicago and made 600awhp on a Porche dyno.
So that EVO is definately not 700hp :thumbdown
Secondly, that wing is hideos, but to each their own.
No...MNGSX said:Umm all evos have coil on plug!
MNGSX said:The first car does'nt have the stock coils...
The stock coils are DECOP.. Double Ended (DE) Basically two on the plug with two short plug wires...
The second pic is SECOP.. Single ended (SE) one coil per plug....
It's the same system they made for DSM's Adapted to a EVO VC...
MNGSX said:Thats kool My main point in this thread is that the car in the article was all rice and ice and the ET's wont be nice.
I think it's safe to assume the car is turned off when the pictures were taken, although his nitrous gauge has the needle maxed out....guess that's where it sits when the car is off.Infinity said:Are those gauges photoshopped?
Why is the boost gauge at 30lbs vacuum. Shouldn't it be at 0?
Perhaps the car was deaccelerating when the pic was taken, which would mean he has crankwalk because there's no oil pressure. He's screwed, the rice has screwed with the performance.
Georg51 said:I think it's safe to assume the car is turned off when the pictures were taken, although his nitrous gauge has the needle maxed out....guess that's where it sits when the car is off.
