- Thread starter
- #201
1cleangsx
- 1,105
- 1,259
- Sep 28, 2013
Cheyenne,
Wyoming
I would think that PPG gearset adds a new level of crazy every time you drive it
I’ve got 206 miles on this motor/trans/turbo setup so far, the good news is I think the rings seated great, no blow by, nothing enters the catch can, but as im posting this the issue im pulling my hair out over is the transmission/clutch drag. At one point the car passed the 7000rpm test, then I adjusted the master rod to try and smooth out the 1st gear engagement which I guess put air into the line and caused it to drag again. So I’ve since installed a new OEM master with a 2g rod, however that made no change at idle, the car would not go into 1st no matter the position of the master rod/shifter linkage. So im gonna buy a new OEM slave, bench bleed it, replace the 2g rod in my 1g master with a 1g rod and bench bleed it and then bleed the SH%T out of the whole system and if I still drag at 7000 im buying a twin ..here’s my new OEM master with the longer 2g rod, but the car would NOT go into 1st when running, no matter the position of the cables/master adjustment rod, so I’m putting the 1g rod back in, and like I said going TWIN if I can’t get this south bend to release!
This car is about to be for sale.
We've all been there. It's a good thing I didn't live near any cliffs when I was building up my 1g.Just kidding Tony , I’ll never sell her just venting haha
....thats something all of us has said at one point. Yet, here we all areThis car is about to be for sale.
CheyenneI just seen you're in WY. Where at?
I'm over here in Rapid City, SDCheyenne
How do you fix the sending unit?That’s weird. Check resistance at the plug (pump side). Iirc there’s 4 wire, power & ground for pump and the other two are for the level gauge. If you there’s no reading, it’s the sending unit which you can probably fix.
