Resolved 6 bolt block freeze plug size???
Status
Not open for further replies.
35mm, make sure you use brass if you order anything other than oem. I've always had troubles with the steel plugs so i use the brass with brown permatex.
what makes the brass ones better? I actually used a steel one, and i used some kind of indian gasket maker. Made by permatex..
And the only reason i used the steel one was all the others were steel. I had a issue where 1 blew out. But i would like to use these brass ones, i am just curious why they are better? And who sells them?
My machine shop installed steel ones with a paste sealer on the mating surface. I'll be really surprised if one leaks, i was there when the owner installed them in my block and it took a good pounding to get them in.
I think I can help with that I'll check on my basement I have a brand new set going into my car soon my says 35mm
Status
