power=dsm
- 268
- 2
- Aug 22, 2003
I got this information elsewhere I have confirmed it from 2 sources who had the ability to check it.
A 4g67 head has the same large ports as a 4g63
dohc head. However their combustion chambers are 43cc vs. 47cc of a 4g63 head they are a complete bolt on. The head nets an extra .4:1 compression so if you have 7.8:1 pistons if you swapped the head to a 4g67 head you would end up with a static compression ratio of 8.2:1. Mate a 6 bolt block a 4g67 head and some 2G pistons almost end up with 9:1 compression.
can anyone confirm this
