1Gina2G
- 810
- 2
- May 6, 2011
Beaufort,
South_Carolina
okay guys well i have the transmission off this 4g64 as im replacing the clutch, i cant see a pivot ball anywhere at all in this bell housing, or behind the fork, is there a chance it doesnt have one? or is it more likely broken off? i didnt have any shifting issues prior to removal. would this mean if i need to shim id have to do it at the slave cylinder or would it gave to be behind the flywheel? if so what i use for the flywheel? i have an aftermarket stage 1 clutch and resurfacing my oem flywheel so i feel as if i could use a shim. thanks in advance!!
