- Thread starter
- #26
jesse12345
- 455
- 329
- Jul 30, 2014
Down the block,
Minnesota
Still test fitting and everything seems to be lining up alot better than how it did before. I'm super happy how everything is going.
The build is looking great man!Didn't really get alot done but I got my tail lights all wired up correctly and as clean as I could. Talon to eclipse rear end complete. I'm very happy with how it turned out. I also left the old wire there if I ever want to convert back easily.
Thanks man it's coming along nice. As for the reverse lights I used a test light and found which wire was for the reverse. I cut the plug way back so I could keep it looking factory. All the wires were the same color. The brake lights were a little tougher to figure out but wasn't bad that was really the only wire I had to cut was for the brake and reverse. Otherwise everything else worked normal I didn't have to swap any relays or anything like that.The build is looking great man!
I'm just curious on what you did with the reverse light wiring?
I did my tails over 10 years ago but didn't do much with the reverse lights after blowing a couple fuses haha.
I know there are past threads for this but figured I'd ask you since you just went through it. Was there any type of mod you needed to do to the reverse wire connections to get it to work right?
Thank you! I plan on staying front wheel drive for now until I'm able to source awd parts. That'll be the next big project on this car. I really appreciate everyone that's been following and commenting it definitely keeps me going.Props for taking this on man. Are you staying fwd?
