- Thread starter
- #26
hollywood_ikr
- 309
- 7
- Jan 17, 2006
el paso,
Texas
the only RWD transmission options for a narrow block(DSM) 4g63 are
MM/D50 2.0 automatic AKA baby 904/torqueflight
or make an adapter plate to bolt to a better transmission... T56, th350/400, 727, t5, etc
wide block you can use:
any MM/D50 2.4/2.6 or any manual 2.0... 3.0(6g72) i am unsure about
RX7 transmission with b2600 bell housing
starquest
and again the adapter route, there's a guy that sells TH350/400 to wide block adapters and i believe he also sells a custom bell housing for a RX7 trans(maybe for narrow block?)
a 4g63 Z would be bad#ss... 200Z.
Thanks this is very helpful! I should also mention I won't be doing this on my own and will be using plenty of professional assistance.
Have you guys seen this spitfire?
Check this site out. :: Project Zero G ::
Using a Mighty Max transmission is a little more involved than you might think, and you may discover that one of the other options is more viable.
Thanks a ton! I think this site will be extremely helpful!
