dsmcrzy
- 1,632
- 346
- Dec 20, 2009
Trenton,
Ohio
Hey guys I'm hoping some one here can help me out! I'm having some weird issues with my rebuilt 420a. I got the engine from a rebuilder (name being with held) and the first engine ran for 4 miles. Got it covered through their warrenty and the second engine went for 2000 miles before it spun pretty much every bearing in the bottom end. So I descided to rebuild it myself this time. Since some parts only had 2000 miles on them I reused them but here is a list of what is new:
Cranck shaft
Eagle rods
Wiseco 8.8:1 pistons
King main and rod bearings
Fel-pro mls head gasket
Oem head bolts
PT style lifters
After putting the engine in and starting it all it did was blow white smoke out the tail pipe and sputter but stay alive. It had power and I drove it for 10 miles trying to clear it up thinking it was just oil from the rebuild. I took it to my mechanic because there is a loud click in the head (lifter tick??) and it won't stop smoking.
So today we (my mechanic and I) did a leak down and compression test. Both had good results for a healthy engine. the compression was 130 134 140 135 but keep in mind this motor really isnt even out of break in period yet.
Here are the problems:
1) Loud ticking in the head
2) It is building pressure in the bottom end (like the rings are bad)
3) Oil is pooling up on the pistons
The compression test was donw with oil pooled on the pistons and with the pistons cleared off (some hoe the oil went away) and the compression was still good.
Any help is greatly appriciated since my mechanic and I are both puzzled. I am pulling the engine tomorrow to tear it back down but I'm here looking for any help of ideas.
Thank alot guys!!
Cranck shaft
Eagle rods
Oem head bolts
PT style lifters
Thank alot guys!!
