1. Join the Community!
2G 420A roadcourse reliability
Posted by RWD4G63, Feb 21, 2020
Please Support JNZ Tuning
Please Support Feal Suspension
  1. RWD4G63
    RWD4G63 Proven Member
    374
    82
    Joined Dec 7, 2011
    Paw Paw, Michigan
    So it looks like I'm going to be acquiring a Talon Esi, it's stock and automatic. Far from the best vehicle for racing, but I'm absolutely going mad wanting to get some track days in, and my other projects are a ways out. Does anyone roadrace or autocross their 420A? Can you comment on the reliability factor? Of course I'll be doing all the regular maintenance items straight away, but any issues I can correct before I discover them myself would be great!
    Road Race Build 230  3
    1997 Eagle Talon TSi AWD
    awd · manual · 2G DSM
    Loading...
  2. eclipse420ags
    eclipse420ags Proven Member
    231
    3
    Joined Feb 20, 2010
    Martinez, Georgia
    I would invest in a crank scaper. Our oil pans have zero baffling/windage tray to keep oil in the pan on hard turns.
    RWD4G63 likes this.
  3. RWD4G63
    374
    82
    Joined Dec 7, 2011
    Paw Paw, Michigan
    Solid idea, thanks for the advice!
    Loading...
  4. Ludachris
    Ludachris Founder & Zookeeper
    3,702
    1,131
    Joined Nov 12, 2001
    Roseville, California
    Let me know how that goes at the autox. I can't imagine running an automatic, though I know people do it. You'll probably have some fun regardless.
    Street Build 9K  0
    1997 Eagle Talon TSi AWD (sold)
    manual · 2G DSM
    Road Race Build 7K  10  23
    1991 Mitsubishi Eclipse GSX
    435.0 whp · 399.2 lb/ft · 1G DSM
    Loading...
  5. turbosax2
    turbosax2 Moderator
    3,384
    199
    Joined Nov 19, 2006
    Mechanicsburg, Pennsylvania
    I can't answer your question since I don't have any experience with the 420a, but I wouldn't hesitate to autox pretty much any car that's mechanically sound. Road course is a whole different story, though, so hopefully a 420a person can chime in to help answer that. It doesn't matter much for autox, but for the road course you'll want some good brake pads and fluid.
    3K  24
    1999 Mitsubishi Eclipse GSX
    13.543 @ 100.000 · 2G DSM
    Loading...
    Ludachris likes this.
  6. dsmcrzy
    dsmcrzy Proven Member
    1,168
    267
    Joined Dec 20, 2009
    Trenton, Ohio
    Street Build 4K  12
    1996 Mitsubishi Eclipse N/T
    fwd · manual · 2G DSM
    Loading...
    RWD4G63 likes this.
  7. RWD4G63
    374
    82
    Joined Dec 7, 2011
    Paw Paw, Michigan
    Thank you! That seems like a solid setup!
    Loading...
  8. silvreclips
    silvreclips Proven Member
    1,113
    298
    Joined Jul 19, 2005
    Greenville, South Carolina
    I've done 1 track day with mine and bunch of autox. Stock oil pan, no baffles or crank scraper. Although those would be a good idea. I would bet with more track time I would see some oil pressure issues, especially will a good set of tires.
    I really haven't had any reliability issues, normal problems that could have happened anyways. The biggest issues I had was oil sloshing in the valve cover and coming out of the vent port on the driver side. It could be because I'm turbo and causing more crank case pressure. I use to run just a small filter on it, and it would shoot oil all over the motor during autox runs. I installed a catch can and during a track day it filled the can up. Maybe 8 oz or more oil.
    So a catch can setup for sure.
    Autocross Build 364  1
    1998 Mitsubishi Eclipse N/T
    Loading...
    RWD4G63 likes this.
  9. RWD4G63
    374
    82
    Joined Dec 7, 2011
    Paw Paw, Michigan
    Are you logging oil pressure? Yeah I don’t plan on running this on slicks or anything close, but I might go ahead and install that Crank scraper setup for safety’s sake, as the car will be a daily for a while.
    Loading...
  10. silvreclips
    1,113
    298
    Joined Jul 19, 2005
    I'm not logging oil pressure but I do have a gauge on the A pillar.
    Loading...
    RWD4G63 likes this.
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
