streetlegends
- 319
- 9
- Sep 7, 2005
Lawton,
Oklahoma
I have a question about gauges. Are the readings different on a 420a cluster then a 4g64 gauge? My concern is that temp gauge goes pretty high before the fans kick on. I use a scan tool and it shows the fans kick on around 208 degrees. Is that the temp they are suppose to kick on? I also notice the gas gauge readings is a little off as well. I am just curious if the ohm readings are different between the two engines.
