1. Join the Community!
4 month old e85 = white smoke
Posted by TK's9d2TSi, Oct 25, 2020
Please Support Kiggly Racing
Please Support ExtremePSI
  1. TK's9d2TSi
    TK's9d2TSi Supporting Member
    4,041
    1,507
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Since e85 is hygroscopic, will it cause white smoke after sitting 4 months?
    522  3
    2000 Jeep Cherokee Sport - Classic
    awd · automatic · Misc Vehicles
    552  4
    93 Civic 4 Door -sold-
    fwd · manual · Misc Vehicles
    Street Build 3K  5
    1992 Eagle Talon TSi AWD
    12.2 @ 120 · 1G DSM
    Loading...
  2. Widgmaster
    Widgmaster Supporting VIP
    432
    310
    Joined Aug 24, 2018
    Sarnia, ON, Canada
    From what I read E85 will absorb water and water is the cause of white smoke...
    While searching out an answer to your question I came across the dumbest answer ...This guy ( no names mentioned ) says maybe it`s brake fluid getting into your engine ...Okay .. you can stop laughing now...
    156  12
    1969 Volkswagen Electric Cart
    rwd · automatic · Misc Vehicles
    153  1
    1977 Glastron Aqua Lift
    180  1
    2002 Dodge Dakota Extended Cab
    354  10
    2001 Mitsubishi Eclipse Spyder GT
    fwd · automatic · Misc Vehicles
    Loading...
    iHavok, JKSleepers and TK's9d2TSi like this.
  3. JKSleepers
    JKSleepers Supporting Member
    9
    5
    Joined Oct 24, 2020
    Cale May, New Jersey
    Seems like there is a little more to unpack here. The short answer is yes, IF a large amount of condensation built up in the tank over those 4 months. Was the car smoking previously? A quick test to see if there’s water in the E85 is to take a known amount from the tank (10mL) and then get some gasoline and mix the two together. If there is separation between the two when you mix it then you have water in your E85. If not, it could be the E85 tune. I hope this helps.
    Road Race Build 204  11
    1995 Eagle Talon TSi AWD
    awd · manual · 2G DSM
    Loading...
    TK's9d2TSi and Vegas Smith like this.
  4. TK's9d2TSi
    4,041
    1,507
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Good point. Never smoked before but this is a fresh built short block. I’m going to drain the coolant and start it to see if it still smokes. That should tell me if it’s coolant or fuel
    522  3
    552  4
    Street Build 3K  5
    12.2 @ 120 · 1G DSM
    Loading...
    C-note89ky likes this.
  5. JKSleepers
    9
    5
    Joined Oct 24, 2020
    Keep us posted. I’m interested to hear what the results are. Good luck!
    Loading...
  6. Hickory-NC-2Ggsx
    Hickory-NC-2Ggsx Proven Member
    197
    47
    Joined Dec 27, 2018
    Lincolnton, North Carolina
    @Widgmaster a engine can suck in brake fluid. I had diaged a car that came in last week that was stalling and eating brake fluid like no tomorrow. The seal on the brake master was really bad and filling up the booster with fluid. But I will say I've never seen white smoke from brake fluid.
    Street Build 454  1
    Mitsubishi Mighty Max
    manual · 4G63t Swapped
    Street Build 766  1
    1997 Mitsubishi Eclipse GSX
    Loading...
  7. TK's9d2TSi
    4,041
    1,507
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Seems like fuel to me. What do you think? It does get thicker as it gets hotter
    522  3
    552  4
    Street Build 3K  5
    12.2 @ 120 · 1G DSM
    Loading...
  8. TK's9d2TSi
    4,041
    1,507
    Joined Sep 11, 2017
    Cincinnati, Ohio
    I will be buying jugs and emptying the tank. Will update this post afterwards. Thanks all
    522  3
    552  4
    Street Build 3K  5
    12.2 @ 120 · 1G DSM
    Loading...
    Hickory-NC-2Ggsx likes this.
  9. JKSleepers
    9
    5
    Joined Oct 24, 2020
    I’m betting it’s water in the Fuel. :thumb: Hoping for an easy fix for you.
    Loading...
    Hickory-NC-2Ggsx and TK's9d2TSi like this.
  10. Widgmaster
    432
    310
    Joined Aug 24, 2018
    Sarnia, ON, Canada
    Thank you for correcting me .. I can see how that may happen ..
    156  12
    153  1
    180  1
    354  10
    Loading...
  11. motomattx
    motomattx Proven Member
    3,149
    1,114
    Joined Dec 9, 2010
    wampum, Pennsylvania
    What does it smell like? it kind of looks like steam to me.
    Drag Race Build 4K  10  24
    1995 Mitsubishi Eclipse GST
    fwd · manual · 2G DSM
    Loading...
  12. TK's9d2TSi
    4,041
    1,507
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Smells like e. I didn’t put coolant in just water
    522  3
    552  4
    Street Build 3K  5
    12.2 @ 120 · 1G DSM
    Loading...
  13. motomattx
    3,149
    1,114
    Joined Dec 9, 2010
    Drain the water and see if it still smokes.
    Loading...
  14. TK's9d2TSi
    4,041
    1,507
    Joined Sep 11, 2017
    Cincinnati, Ohio
    I did. The video in post 7 is with system drained so that’s why I’m pretty sure it’s moisture in the fuel
    522  3
    552  4
    Street Build 3K  5
    12.2 @ 120 · 1G DSM
    Loading...
  15. jed344
    jed344 Supporting VIP
    1,003
    157
    Joined Jan 10, 2008
    Waterville, Iowa
    Depending on temp my car when warming will sometimes smoke a light white till warm. This is on e85 tested at 85% and it goes away once car warms up. There is zero smell to it.
    1K  38
    Loading...
  16. TSI_STI401
    TSI_STI401 Probationary Member
    3
    Joined Oct 21, 2020
    NORTH KINGSTOWN, Rhode Island
    Does it keep getting worse as the car warms up ?
    Street Build 145  1
    1990 Eagle Talon TSi AWD
    awd · manual · 1G DSM
    Loading...
  17. TK's9d2TSi
    4,041
    1,507
    Joined Sep 11, 2017
    Cincinnati, Ohio
    It has been sitting for 4 months
    Little thicker than what you see in the video but it doesn’t linger.
    I’ll be emptying it today
    522  3
    552  4
    Street Build 3K  5
    12.2 @ 120 · 1G DSM
    Loading...
  18. TSI_STI401
    3
    Joined Oct 21, 2020
    around where i live most of the e85 is really like e68 i run it in my sti. depnding on the weather the exhaust has a (steam) look to it. yours doesnt look to bad. im iterested in how this turns out.
    Street Build 145  1
    Loading...
  19. TK's9d2TSi
    4,041
    1,507
    Joined Sep 11, 2017
    Cincinnati, Ohio
    It’s about 80% here from what my flex fuel sensor reads. I’ll provide an update soon
    522  3
    552  4
    Street Build 3K  5
    12.2 @ 120 · 1G DSM
    Loading...
    C-note89ky and iugrad92turbo like this.
  20. TK's9d2TSi
    4,041
    1,507
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Just finished draining the tank. Will get fresh 93 tomorrow and see what happens. I haven’t seems what e looks like since I’m only putting it in the tank. How does this look compared to fresh e? The smell doesn’t seem as strong. The odor would linger in my garage before and not so much today.
    522  3
    552  4
    Street Build 3K  5
    12.2 @ 120 · 1G DSM
    Loading...
    iugrad92turbo likes this.
  21. Boomdeeze
    Boomdeeze Proven Member
    2,076
    303
    Joined Jul 5, 2009
    Independence, Minnesota
    Just looking at the video, you're idling at ~11.8 A/F, bet that is why you are smelling e85 at idle haha But it does look like steam to me as well as it disappears as soon as it gets passed the garage door. If it is white smoke, it would carry further before disappearing.
    Street Build 5K  1
    10.793 @ 128.98 · 2G DSM
    Loading...
  22. TK's9d2TSi
    4,041
    1,507
    Joined Sep 11, 2017
    Cincinnati, Ohio
    It was cold start and afr goes to normal within a minute but same steam/smoke so it’s definitely not from using rich
    522  3
    552  4
    Street Build 3K  5
    12.2 @ 120 · 1G DSM
    Loading...
  23. TK's9d2TSi
    4,041
    1,507
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Welp it wasn’t the fuel. I’m going to pull the head and send it to the machine shop. I really hope that’s it.
    522  3
    552  4
    Street Build 3K  5
    12.2 @ 120 · 1G DSM
    Loading...
  24. JeffGS-T97
    JeffGS-T97 Supporting Member
    202
    55
    Joined Mar 22, 2019
    Muncie, Indiana
    I ran into a similar issue and it was an issue with venting the crank case i tried using a closed catch can. Changed back to the JAZ filter top and it went away. Just a thought.
    Street Build 2K  8
    1997 Mitsubishi Eclipse GST
    Loading...
  25. TK's9d2TSi
    4,041
    1,507
    Joined Sep 11, 2017
    Cincinnati, Ohio
    I wish that was my situation. LOL
    522  3
    552  4
    Street Build 3K  5
    12.2 @ 120 · 1G DSM
    Loading...
Share This Page
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
