- Thread starter
- #26
eXploitedGST
20+ Year Contributor
- 289
- 0
- Jul 27, 2002
Milwaukee_WI
probably not since the whole exhaust system would be custom (flange angles, length of dp, ect.)
No.Originally posted by H.A.R.T 4G63DSM
I was thinking of getting a 3 inch downpipe but now I wanna get a 3.5 downpipe. Would I make more horses?
Originally posted by Clipse
Not unless your running a T78 or something of the like
Originally posted by eXploitedGST
bigger exhaust = fast spool, but i dont want to a cut out, id rather it go strait out the back
Originally posted by mitch83
sup swing lo this is usaf-jdm from the kutsuju board. anyway I didnt see anyone mention that massive boost creep you would get unless you were running like a 40mm external wastegate. but with a 14b,16g,18g, or 20g with an internal wastegate you would get mad boost creep because the exhaust would rather flow out of the turbine discharge then the tiny little internal wastegate. just my $0.02
mitch
Originally posted by gsxstac
let me modify this a tad
0-300whp = 2.5" exhaust
300-700whp = 3" exhaust
700-800whp = 3.5" exhaust
700-900whp = no exhaust
this argument is like saying a 10" exhaust pipe is better then a 9" one. the outlet on the turbo is 2.5" at most so a 3" exhaust is fine. plus at full throttle prob a 1/4 of the exhaust is going out the external gate anyway. i've seen well over 600 whp on 3" exhaust. if its mandrel bent and its on a gsx theres barely any bends anyway. I just cant see someone actually having backpressure when there exhaust tubine is 2.5" and they have 3" exhaust thats mandrel bent and pretty much straight. jus think about it. is exhaust flow from a 2.5" hole really gonna have back pressure???
Originally posted by revision27
man if you people want to buy a 4" exhaust go ahead and waist your money. it is pointless trying to convince someone to change their mind about something they are hell bent on.
Originally posted by fastaseagle
you could just run a 3 inch exhaust with a dump tube that would be the same as a 3.5 or maybe even 4 inch exhaust do to the exhaust going out the dump...
