4 digit security code???
Big_swedish
Sep 30, 2004
Mission Viejo, California
I just got my car back after having several mods installed... My Stock CD player is now unable to play CD's and is asking me for a code.... Where can I find/obtain this code???
call up the dealer and ask them for it. but you have to have your serial number for your player. remove the a/c bezel and it should be on the top of the unit. they need that to look up your code. if they try to charge you, come back here and im sure someone has a dealer phone number that will do it for free ( i for example) just try your dealer first. goodluck !
or you can do what i did. punch in 4 numbers starting with 0001 and so on. if you have a passenger let them do it. enter the number and press "cd" or "radio" till it turns on. it will eventually work if your lucky. my number was not that much so it didnt take that long to get to it.
Which will lock up the radio after the fourth failure, and require that it sit for an hour with the power on and the ignition off. :rolleyes:
You need to take the serial number off the radio, and take it to a dealer. Some try to charge for it.
http://www.dsmtuners.com/forums/showthread.php?t=191682
defiant is right the same thing happend to me take it out and look at the serial number and call the dealership they should give you the code be sure you write it down and don't lose it ROFL :p
actually mine never lock up and i tried it so many times. i only did it that way because the dealer tried to charge me 57 bucks.
