DSMStyle2G
- 5
- Jun 24, 2018
South Bend,
Indiana
So I'm wiring up my AEM Tru-boost, Wideband, and oil pressure gauges right now on my 2g. I would like to tie all 3 of the power wires together into 1 for the power and do the same with the ground wires.
Initially I was going to do this and use a fuse tap but then found out it will not fit into the fuse box so that ideas a bust. I've been doing research and looking on the forums for where I could get power and I'm thinking of tapping into the cigarette lighter, but I haven't seen where anybody has had all 3 gauges powered by the cigarette lighter all at one time, so is this safe to do so?
Also all of the AEEM gauge instructions recommended 5 amp fuse for each gauge for install. If I tie all of them together and power them through the cigarette lighter the stock 15 amp fuse for the cigarette lighter should be sufficient right? Or do I need to add some 5 amp fuses inline?
I don't ever use the cigarette lighter but wanted to ask before I found out the hard way. Any help would be appreciated. Thanks in Advance
