e96eclipse
- 51
- 0
- Jan 3, 2010
vanceboro,
North Carolina
ok so i got three different codes on my 98 eclipse non turbo.... i need some help! I have a P0171 (which says System too lean-cylinders 1-4), and a P0132 (which says cylinders 1-4 heated oxygen (front) sensor circuit), and also P0134 (which says cylinder 1-4 heated oxygen (front) sensor no activity detected)..I know my O2 sensor up front needs to be changed but i recently installed a aftermarket upper intake and wanna make sure if i change that sensor its going to fix the prob! All four cylinders are lean? will one sensor make all cylinders lean? Help please....
