Please Support ExtremePSI
Please Support Rix Racing
420A 2gNT Loose pulley
Jonnychance
74
Jul 2, 2017
Cashmere, Washington
I was watching this pulley it seems to move quite a bit. I'm sure I need to replace the belt because it squeaks in the cold but I might as do both. Video below of pulley. Middle video I hadn't re-tightened the tensioner yet.
BLACK'98DSM
3,693
1,332
Feb 9, 2019
Alabama
This is the 420a, the water pump is not driven by the serpentine belt but instead the timing belt.
It is possible that the power steering pulley is warped. I had to replace mine at one point. But just for an easy check make sure the nut that holds the pulley on the shaft is tight.
Jonnychance
74
Jul 2, 2017
Do you the torque specs for that bolt I can't find anything in the haynes manual.
Boosted Fabrication ECM Tuning ExtremePSI Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com RixRacing RockAuto RTM Racing STM Tuned
