2G WOT Pull, Stop, Pull, Stop Jerk
pointblank9957
284
10
Jul 12, 2012
Sheboygan, Wisconsin
1998 Spyder GS Turbo
When i WOT, my car will pull fine up to ~3750rpm and then it seems like it cuts ignition, On, Off, On, Off, etc.
Walbro 190 FP
SFI 660CC Injectors
12psi Boost level
any advice?
EDIT: two of the vacuum lines were mixed up... everythings good!
Moar fuel...
i tried lowering the AFR's on the High Octane Fuel Map for above 100% Load .7:1, still happens :/ the AFR isat around 11:1-12:1 when it happens
