DSM B
- 43
- 11
- May 22, 2012
Minneapolis,
Minnesota
Hey guys, I am trying to improve my idle and I can only get the vacuum to 16.4 in hg at best. I do have 268 (GSC S1) cams and I am wondering what vacuum people with those cams have.
When I watch my wideband, it does seem to bounce around mainly lean and the idle is not rough, but it is not smooth either. There seems to be small idle misfire stumbling's. I am suspecting a vacuum leak and I have done several BLT's that have not pointed toward any vacuum leaks, but I could be mistaken.
I am set up with speed density and I still want to rule out any vacuum leaks, so I am wondering what people with the same cams have.
My fuel trims and Airflowperrev seem to be inline, yet my car still runs lean according to the wideband. I do have adjustable cam gears, I did adjust them to improve the idle vacuum and it did not improve, 16.4 seems to be the best I can do.
I am wondering if my throttle body has a small leak, I did replace the throttle shaft seals and I do have FIAV bypass plate installed. I don't know if I have small leak somewhere in there maybe that I BLT just isn't picking up.
Attached is a log for review, I am open to any advice or feedback. My injectors are Bosch 1600 HiZ injectors and I do have dyno acr 2 on my ignition.
Thanks
Thanks
