1995-tsi-awd
- 131
- 14
- Jul 17, 2013
Fort Worth,
Texas
This thread was created to walk through the emissions removal on a 95-96 2g dsm. After reading some of the comments posted on the "How To's" it was apparent that some people are more visual learners rather than reading to one picture/diagram. I pulled my emissions last night and took some pictures while doing so. Hopefully this will aide others in pulling their emissions related components.
Before you get started I highly recommend purchasing a EGR block off plate from ebay unless you can fabricate one yourself. They are $10 with free shipping. I removed my emissions before ordering one and spent more time fabricating one than I hoped for.
Time to complete:
30min (purchased block off plate, not repainting parts)
2hrs (fabricating block off plate, repainting parts)
Things you will need:
Block off plate for EGR - Ebay or fabricated
Cap for intake pipe (not sure on size.. already had one 1/4"?)
4x 1/8" vacuum caps - sold at auto parts store
Things I recommend:
10ft of Vacuum line to replace old line (this stuff is less than $1 per foot)
Let's get started.
So you lift the hood up and you're looking at all those vacuum lines and you're not sure what's what and you don't want to screw things up.
That's ok. We are going to start small and work our way up to the hardest part.
Let's first post an image of the before and after for reference:
Before:
After:
(turbo, mbc, and wastegate routing could be different on your installation; see step 14)
1. Remove Battery, battery tray.
2. Unbolt both battery support brackets.
I get these brackets out first because if you need to repaint it can dry between coats while you work on the rest.
You should now see this:
You may have had to unbolt the charcoal filter to get the battery brackets off. That is ok, but for now leave all the hoses attached. Again, we are starting off small for the newbies.
3. Time to clean, then paint those old rusty battery brackets. (optional)
Between coats, continue on!
4. Find your fuel pressure solenoid and remove the vacuum lines from the solenoid.
You have two options at this point:
A. You connect the manifold directly to the fuel pressure regulator
B. You connect the manifold, fuel pressure regulator, and boost gauge through a T
Now that wasn't so bad was it? Fuel pressure solenoid done!
5. Find your EVAP solenoid and EGR solenoid and pull the 4x vacuum lines.
6. Now pull the 3x lines from the throttle body.
7. Put on 3x vacuum caps on the throttle body.
At this point you need to stop and have a look behind the intake manifold and realize your throttle cable is back there. Be careful with the next step!
8. Remove the vacuum hose on the side of the EGR solenoid and unbolt the hardlines that are welded together. (2 bolts on back of intake manifold)
9. If you trace the vacuum lines down the backside of the intake manifold you will find two lines running to your EGR valve. You need to remove these. Picture shows EGR circled.
10. At this point you have two options:
A. Gently pull off the vacuum lines and mess with the T on the back of the intake manifold in hopes of salvaging the hose.
B. Cut the vacuum lines to pull them out and the hardlines welded together.
Either way you should end up with this:
11. Follow the remaining vacuum lines back to the charcoal canister.
Unbolt the canister assembly. (if wasn't done so previously)
Unplug the vent line from the firewall to the charcoal canister. I just tied this up to the firewall.
Unplug the vent line to the intake manifold.
Pull out the canister assembly. You should now see this on the ground.
12. Cap off you intake pipe (not sure on size already had one).
At this point or even at the end you can unbolt the EGR valve and bolt in your block off plate. It's two bolts, pretty straight forward. Some people use RTV, I just reused the metal gasket that was there previously.
13. Remove intake filter and locate your wastegate solenoid below. Remove both air lines from this. Trace those back to the T and remove the air line from your turbo and wastegate.
14. You now have three options:
A. Connect the turbo directly to wastegate (run wastegate pressure) and cap intake.
B.
C.
15. If you haven't done so already, unbolt the EGR valve and put on the block off plate.
16. Install battery brackets, tray, and battery.
17. Fire it up!
During this installation I did not remove the electrical connections/connectors. It is probably possible, but you will need some way of turning off the CEL that could spawn from doing this.
That's pretty much it.
Good Luck!
Time to complete:
Things I recommend:
Let's get started.
Before:
After:
B.
C.
17. Fire it up!
Good Luck!
