2g talon awd standard trans W5M3 diagram
98talonawdtsi
Mar 26, 2023
MB_Canada
New to the forum. Looking for a diagram or photo of shift fork assembly. I pulled the trans apart about a year ago and now can't recall the reassembly sequence. If you have additional assembly info for the trans that's ok by me! Thank all.
Hows this
DUDE! You are a savior! Thank you! Do you have other views (like a 360 degree of the one you sent? ) pulled it apart thinking it won't be long... then life happens... and a year later I'm wishing I took more pics!
I actually grabbed that off of Google. If it makes you feel better, I had NEVER had a W5M33 apart until last year. They were "intimidating" me with the 2 rail shift system but once I got it apart, it really is a piece of art. I understand them now and put 2 transmissions together that were in totes and just parts. I use them as "test" transmissions if I have a question. I just take the bolts out (I didn't seal either trans) and take a look. The following pictures are a 1g AWD but are so close to the same, you should be able to see what you want. I took pictures as I went back together with mine. Here they are:
  • To do the job.docx
Hey thanks. That's awesome! Quick rookie question W5M3 vs W5M33? Anything to be noted?
Quick smartass answer - its missing a 3
To my knowledge (and it isn't that vast on Mitsu transmissions), there isn't just a W5M3.
@steve??? What you say???
Quick whimsical response... oh ya? LOL Clearly I'm a rook so my ears are open.
and in terms of the pictures posted above. mine is like the first pic with the three hole shift fork. This also might be a franken car so maybe my numbers are unknowingly off?
There is a flat boss that has the serial numbers on it on the transmission. It will say W5M33 :)
Why wasn't I on here long ago? Thanks y'all! Hopefully I can get this reassembled and back on the road. Don't see many around so it's neat to bring a bit of nostalgia back to the street scenery
The reason it has a W5M3 only on that spot is because they used the same casting for W5M31 and W5M33 cases.
I was NOT going to smart ass and remark that the case fit W5M30 thru 39 transmissions.
Thanks @steve and @twicks69 for that clarification for the thread.
@98talonawdtsi , the MAN to ask about this is @twicks69 .
He is the transmission GURU so his word is as good as it gets. He helped me get my transmission parts and assembly along with @pauleyman .
Those guys were of the most help to me and I can never thank them enough.
I need to go easy, it seems like I've been scaring off the new members lately. They ask something, I ask them to say it so I can understand them, and they run off.
The wife says it's making me cranky and thinks I should move to Galt, CA
