AZmocoLoco
- 209
- 49
- Feb 23, 2016
Chandler,
Arizona
Im getting my car buttoned back up for boost season but ran into something I haven't been able to figure out.
While performing a pre drive walk around, I witnessed my tail lights fade away until the point where they were completely off and inoperable, then noticed my cluster was out as well. Blinkers, reverse, headlight, fog lights, interior courtesy lights all work. I checked all fuses, relays, and swapped them around with known good and had no change. I swapped my courtesy dimmer switch, and my steering combination switch with no change. What could have caused the lights to FADE away like that? Am I missing a relay or circuit somewhere? Could a bad bulb cause the cluster lights issue as well? Help much appreciated!
