EC17PSE
Freelancer
- 5,885
- 3,478
- Nov 1, 2008
London, UK,
Europe
Hello all.
I thought I would post this up because it might be of use to some of you,
***** NOTE ***** This is for the tailgate/hatch window only!!!
Recently got my side windows made from a company that specialise in racing windows and i had mine made in hard coat poly and next up for me is the rear curved window which is to be thermo formed and I have asked the owner of the company if they would be interested in doing more and they agreed to it and if a few are on board then they would even make a proper mold for it so it will always be available to us in the future! if not then I might get one maybe 2 off the glass before it breaks and no more can be replicated after that!
I have got a few prices and they are in pounds and converted to current rates and the rates will alter for you (check XE.com) for most current rates but the pounds will always stay the same. I dont have any control on these prices and its exactly what I myself will be paying.
3 options available!
normal poly-carbonate is £190 or $233
hard coat poly-carbonate (best scratch resistant and fuel/chemical resistant) £275 or $338
Tinted poly-carbonate in Grey VLT 55% or bronze VLT 50% £200 or $245
normal poly-carbonate has good scratch resistance as well as the tinted but the hard coat has the better resistance and also against things like fuel and cleaning products. All windows are clear and see through, windows in the pic have its protective coating on still
Details of the window,
will be slightly over oem sized to eliminate the factory rubber seal to give a neater and cleaner look and be a bit more aerodynamic, it will be a good fit and no trimming required,
also will come with black primed as oem distance read for bonding in. Not to mention poly windows are about 50% lighter then glass also. Good weight savings to be had.
Stock oem glass 22Lbs
ACW poly window 11Lbs
Shipping will be based per customer as you will need to email or call them to place your order and get your shipping prices direct from them. BUT for reference a rear window quote shipped to California is £66 or $81
so for me I think if I can help you folks out as I always try to do then I will and this is a decent price even for you folks.
if you are interested post up here and lets see what kinda numbers we will be looking at as I will be likely to put my order in for my window in a month or 2 so if we can do something by then when the glass can still be used for the mold great.
any questions or details on something you think off I might have missed out just ask.
THESE PICS ARE FOR REFFERENCE ONLY. this is what they made for me recently to show their work so far they made for me to my exact specifications and they hold up to the car perfect.
The post is is for the tailgate/hatch piece only
those interested.
@ec17pse HC
@mountain_man HC
@91talonts1 HC
@llxkevinxll HC
@mitsumikey HC 1 pos (2)
@Jacolu3 HC
@Maddashimports-Matt Brnz
@GSTTOBEAT GR
those interested.
@ec17pse HC
@mountain_man HC
@91talonts1 HC
@llxkevinxll HC
@Jacolu3 HC
@GSTTOBEAT GR
