PieEyedPiper
DSM Wiseman
- 5,580
- 65
- Nov 13, 2004
North Bay Area,
California
I've made this new thread because I've narrowed my problem down some and the old thread was cluttered.
Problem: Code P0300, (i think?) Random Multiple Cylinder Misfire. When I'm on the HWY, keeping the RPM's steady, my car will eventually throw this CEL and the car will vibrate and stutter like mad.
Temporary Solution: While cruising at around 70-80mph, and I encounter this phenomenon, I take the car out of gear, shut it off, allow the RPM's to hit zero, restart the car, put it back in 5th and carry on my merry way.
This is NOT desireable.
I have new plugs, NGK BPR6ES gapped at .028, I've cleaned my Accel Thundersport wires and attempted to test my coil pack.
I have this diagram, shown to me by another helpful DSMTuners member, http://dsmtuners.com/forums/attachme...1&d=1088544507
I cannot really make sense of it. Too many shadowed testing positions etc.
Plus I can only find two things to test on the coilpack.
The PDOB (poorly drawn offensive bitmap) should hopefully show up somehwere in this thread.
I get ~20Kohm in my voltmeter by testing the two ports on each coil pack. Both packs yield identical results. I cannot find a third port to test.
The car otherwise is running as strong as ever @ 15 PSI with a 1g bov and a MBC connected at the bov line.
Now all I need is some more direction.
Thanks!
Thanks!
