Flatout Suspension
Supporting Vendor
- 38
- 62
- Sep 24, 2020
Baltimore,
Maryland
Guinea pigs are lined up...stay tuned for updates!
I'm ready to start gearing up on producing coilovers for you guys and I've had a ton of response here; so let me first thank you all for the warm welcome. What I'd like to do is start with a baseline. I already have the specs I need to pump out 2G AWD and FWD coilovers, but I'd like to pair up with someone that's currently in the market so we can both help each other.
I'd like to do our entry-level SR model to establish a baseline for things to come. I don't necessarily want to build the craziest thing we can possibly build right off the bat. So, even though I say "entry-level" you'll still get the bells and whistles:
SPECIFICATIONS:
The goal in mind here is to have a suspension that your average car guy would like, so I need you to be subjective in that respect. If you didn't see this post, and you just found us by accident and ordered; would you be happy? Make sense?
On our site, I have the Eclipse/ Laser/ Talon listed, but in this scenario, the Laser isn't a factor. If you want to dive in, let me know and I'll give you a code to use on the site. I really only need one person...but I'm also not opposed to doing a second to maybe see if your reviews are similar.
https://flatoutsuspension.net/products/mitsubishi-eclipse-coilovers-sr
Questions?
SPECIFICATIONS:
- Designed for Street Comfort
- 2 Front Assemblies
- 2 Rear Assemblies
- Radial bearing on Front Assembly
- Linear Rate Springs
- Electro-Plated Steel Cartridge
- Rebuildable Monotube Shock
- CNC Machined High-flow Aluminum Piston
- Stainless Steel Shims
- Medium Weight Synthetic Shock Oil
- 650/350 spring rates
- Rebound Adjustable : 20pts
- Spherical bearing upper mounts standard
- Individual Parts Available
- 3-Year Warranty Against Defect
- Approx 2wks to hand assemble and ship
Questions?
